[Mapbender-users] Problem with grouped layers and GetFeatureInfo
Clemens Beyer beyer at multimediaplan.at
Tue Feb 17 09:37:13 EST 2009
> you don't doing anything wrong.
> As far as i know  Mapbender doesn't support grouped queryLayers.
> But there is a trick you can do it.
> To solve your problem you have to connect to your Mapbender
> database via
> phppgadmin or pgadmin3.
> Open the table gui_layer  and search your layer_id. (in your
> case its
> fkey_layer_id = 20622).
> Now you have to change the values of :
> "gui_layer_queryable  and gui_layer_querylayer"
> from 0 to 1.
> This should be activate your checkboxes and Mapbender will be
> request them.
Thanks a lot, it works fine with this cheat... :-)
Best regards,
Clemens
More information about the Mapbender_users mailing list
