[Mapbender-users] how to connect mapbender to postgresql?
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Thu Feb 19 04:15:12 EST 2009
On Wed, February 18, 2009 1:48 am, MeLv1n wAuRaN wrote:
> hi all,
> i've just installed a mapbender into my ms4w package. at the mapbender
> setup check under database check the connect to database status is not
> connected. And under the mapbender.conf check the DB-server, mapbender-DB,
> DB-owner status are all not defined. How do i connect this mapbender to
> the postgresql so that i can login to mapbender?
> Thanks,
> Melvin
Hello Melvin,
PostgreSQL is not included in the ms4w package. You have to install the
PostgreSQL database.
You can get an installer at:
http://www.postgresql.org/download/windows
Then you can follow the instructions to create the database and fill it
with the Mapbender tables:
http://www.mapbender.org/Installation_en#PostgreSQL_database
Notice: add -U postgres to the commands that you find in the Mapbender
Wiki (it means send the command as user postgres)
Best regards Astrid
More information about the Mapbender_users mailing list
