[Mapbender-users] Re: How to get mb_myBBOX to work
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Wed Feb 25 13:18:19 EST 2009
On Wed, February 25, 2009 11:47 am, Albrecht Weiser wrote:
>> Albrecht Weiser schrieb:
>> > Hi mapbender list,
>> > i wanted to start my mapbender gui with an initial extent. I was
>> reading
>> to use "setBBOX". So i went to the GUI element administration and turned
>> setBBOX on. I set the element ON/OFF to "1" to activate it. Then i tried
>> to
>> set the parameter "mb_myBBOX=", but which element i have to use? I tried
>> the Attributes, Content, Requires, URL and SRC element in the GUI
>> elements
>> administration. i tried with "&setBBOX=" and with "setBBOX". I tried
>> with
>> native SRS-coordinates (Gauss-Krüger) and with WGS84. Nothing worked.
>> Could
>> somebody please tell me, how to fix that?
>> > Thanks
>> > Albrecht
>> Hello Albrecht,
>> have a look at the wiki-documentation
>> http://www.mapbender.org/SetBBOX
>> Here is an example
>> http://wms1.ccgis.de/mapbender2/frames/login.php?name=ccgis_de&password=ccgis_de&mb_user_myGui=MiddleAmerica&mb_myBBOX=-102.92,11.56,-86.37,25.07
>> Best regards Astrid
> Hi Astrid,
> i know this site about Mb myBBOX and the example too. But for a newbie
> like me it's not clear, where to apply the parameter &mb_myBBOX.
> I tried again in the admin-gui "edit elements" to setup the modul
> "mod_setBBOX1.php" (div-id "setBBOX"). I was considering the element "URL"
> the most fitting for this issue. So i copied the URL of the gui
> "http://mapbender.telascience.org/mapbender_2.5/frames/index.php?&gui_id=Albrecht%20Weiser_gui1"
> there and added the parameter "&mb_myBBOX=342800,552990,3441400,5535600".
> The element ON/OFF is set to one, then saved the settings and showed the
> gui. But i still got no initial zoom to my coordinates. So what may be
> wrong?
> I attached two screenshots with my settings.
> Best regards
> Albrecht
Hello Albert,
I added an example Link to my last mail. Here it is again.
Just klick on it and the gui will open:
You can add this link to a webside. So the gui will open with this extent.
Your link could look like this (change user and password in the link)
http://mapbender.telascience.org/mapbender_2.5/frames/login.php?name=XXXX&password=XXXX&mb_user_myGui=Albrecht%20Weiser_gui1&mb_myBBOX=342800,552990,3441400,5535600
If you don't want to open the GUI with a link you could change the extent
of the first WMS in the WMS itself or (if you are not master of the WMS)
you could go to the Mapbender database and change the extent.
Best regards
astrid
Mit freundlichen Grüßen
Astrid Emde
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Siemensstraße 8
  D-53121 Bonn
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
