[Mapbender-users] First steps on Mapbender...
Lluís Vicens lluis at sigte.udg.es
Wed Jul 8 11:26:06 EDT 2009
Hi Astrid and Armin,
It works! Thanks for your help. I've updated the mapbender database
executing the correct sql (update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql) and
then, I downloaded mapbender from branches 2.6 and I replaced the old
folders and files for the new ones...  I don't know if this is the best
way to proceed but it works ;)
Now, I'm starting to work on mapbender and take for sure that I will
come back with tons of doubts :-[
Regards,
Lluís
En/na Astrid Emde ha escrit:
> Hello Llius,
> I hope you took the Mapbender 2.6 from braches/2.6
> You can donload it from
> http://trac.osgeo.org/mapbender/browser/branches/2.6
> (We did a lot of bugfixxes since Mapbender 2.6rc1, so it makes sense
> to take the package from /branches/2.6)
> The error in the logfile says. ERROR:  relation "gui_gui_category"
> does not
> It seems that you don't have run the sql for the mapbender
> installation properly (one table gui_gui_category is missing)
> Please recreate your Database! You find an installation script at
> mapbender/resources/db/install_2.6.sh (install_2.6.bat for windows)
> which will lead you easily through the installation.
> Then you just have to point the mapbender.conf to this new database.
> If you still have problems let us know.
> Astrid
> Lluís Vicens schrieb:
>> Hi Michael,
>> So many thanks form your answer. I've been checking what you told me
>> and as an attachment you will find the mapbender/log file and below,
>> there is the result of executing the mapbender_setup.php
>> For your information, I am (trying) running mapbender 2.6 rc1 on
>> Ubuntu 8.04.
>> Any thoughts?
>> Best regards,
>> Lluís
>> *Warning*:
>> require_once(/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php)
>> [function.require-once
>> <http://localhost/mapbender_2.6_rc1//tools/function.require-once>]:
>> failed to open stream: No such file or directory in
>> */var/www/mapbender_2.6_rc1/tools/mapbender_setup.php* on line *24*
>> *Fatal error*: require_once() [function.require
>> <http://localhost/mapbender_2.6_rc1//tools/function.require>]: Failed
>> opening required
>> '/var/www/mapbender_2.6_rc1/tools/../../core/globalSettings.php'
>> (include_path='.:/usr/share/php:/usr/share/pear') in
>> En/na Michael Schulz ha escrit:
>>> Hi Lluís,
>>> welcome on board :-)
>>> Could you have a look at the mapbender log file that is created in the
>>> /mapbender/log dir? Also it may be helpful to have a look at the
>>> output of mapbender_setup.php. Open this script in your browser and it
>>> will show a lot of information regarding mapbender/database
>>> surroundings. Also, a look in the apache/php error log may give some
>>> information.
>>> Please post any valuable information.
>>> Cheers, Michael
>>> 2009/7/7 Lluís Vicens <lluis at sigte.udg.es>:
>>>> Hi,
>>>> I'm totally newbie to Mapbender and, after completing the installation
>>>> process (now it seems that all it's ok) I proceed to login
>>>> (root:root). No
>>>> errors showed but nothing is loaded :(
>>>> The only result is just an empty page (see attachment). What's
>>>> wrong? Any
>>>> help?
>>>> Thanks in advance!
>>>> Lluís
>>>> map
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
