[Mapbender-users] MB 2.6 RC1
Michael Schulz mschulz at webgis.de
Thu Jun 4 05:10:10 EDT 2009
ok, I think this is worth a ticket in trac. Can you create one? If not
I'll do it and cc you.
Cheers, Michael
2009/6/4  <beyer at multimediaplan.at>:
> Hi,
>> how did install mapbender 2.6 RC 1? Is it a fresh install or an update
>> of a previous version? With a fresh install, did you use the install
>> script?
> It is a fresh install. I did not use the install script but I followed
> the instructions in install.txt.
>> Did you change the permissions of the log folder? If yes, are
>> there any errors in the log?
> The log file displayed that the gettext function was missing in the
> database. I created the function with the SQL from
> http://www.mapbender.org/Database_translations
> and now I can access the other pages. So this part is fine and GUI "gui"
> is loading.
> "gui1", however, says: "Mapbender 2.6 rc1...loading application 'gui1'",
> but then stops with 2 javascript errors:
> * missing } after function body (map.php, line 2263)
> * $ is not defined (core.php, line 18)
> gui2 is showing the background and nothing else. Firebug's error messages
> are almost the same:
> * missing } after function body (map.php, line 3336)
> Best regards,
> Clemens
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
