[Mapbender-users] how to integrate a static legendimage which describe a classified raster map
Peter Freimuth freimuth at rapideye.de
Tue Jun 16 05:03:41 EDT 2009
Hi Michael,
the following command works for me.
insert into layer_style (fkey_layer_id,name,title,legendurl,legendurlformat) VALUES (20318,'default','default','wmshost?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=service_product_gc&format=image/png&STYLE=default&width=120&height=341&rule=GCMap','image/png');
please note that the rule parameter need to be in place. Otherwise umn mapserver is ignoring the width and height parameter.
thanks for the help,
peter
On Monday 15 June 2009 21:09:23 Michael Schulz wrote:
> Hi Peter,
> you have to modify table "layer_style". Be careful to change the value
> of the legendurl of the layers style that is defined in
> gui-wms-settings (default is "default").
> Needless to say, this change will be lost with the next update of the
> corresponding wms ...
> Cheers, Michael
> 2009/6/15 Peter Freimuth <freimuth at rapideye.de>:
> > Hi Michael,
> > thanks for the quick response and sorry list for sending the request again.
> > Yes, we have more than one layer in the request. I will try to modify the mapbender db but maybe somebody could give me a hint which table to start with if i want to change the get legend url request for a layer in the wms.
> > Kind regards,
> > Peter
> > On Monday 15 June 2009 18:16:46 Michael Schulz wrote:
> >> Hi Peter,
> >> is this the only layer in the mapfile? If so, you should be able to
> >> tell the legend obj to create a legend in the size of your keyimage,
> >> and this should be reflected accordingly in the capabilities
> >> legendgraphic section.
> >> The two other mapbender approaches would be:
> >> 1) modify the the getcapabilties-doc manually and don't load the
> >> mapserver dynamic one
> >> 2) modify the mapbender db directly...
> >> But a better solution would be a mapserver enhancement, that would let
> >> you define a layer's static legendicon url via a metadata keyword.
> >> Cheers, Michael
> >> > Hi,
> >> > i would like to use a scecial image like the attached file as an LegendIcon for a raster layer in mapbender 2.5- The Layer is served by a UMN and i know that there is a special attribute called KEYIMAGE which can be used for this. But of course mapbender will request this image with the same size than all other images.
> >> >        CLASS
> >> >            NAME "GC Map"
> >> >            KEYIMAGE "images/GroundCover.png"
> >> >        END
> >> > Any idea,
> >> > Peter
> >> > _______________________________________________________________________
> >> > Peter Freimuth                          phone: +49 3381 8904327
> >> > Product Development                     fax:   +49 3381 8904101
> >> > RapidEye AG                             email: freimuth at rapideye.de
> >> > Molkenmarkt 30
> >> > 14776 Brandenburg an der Havel          http://www.rapideye.de
> >> > Germany
> >> > PRIVILEGE AND CONFIDENTIALITY NOTICE:
> >> > The information in this email is intended for the named recipients
> >> > only. It may contain privileged and confidential information.  If you
> >> > have received this communication in error, any use, copying or
> >> > dissemination of its contents is strictly prohibited.  Please erase all
> >> > copies of the message along with any included attachments and notify
> >> > RapidEye AG or the sender immediately by telephone at the number
> >> > indicated on this page.
> >> > RapidEye AG
> >> > Molkenmarkt 30
> >> > Germany
> >> > Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
> >> > Management Board/Vorstand: Wolfgang G. Biedermann
> >> > Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
> >> > Commercial Register/Handelsregister Potsdam HRB 17 796
> >> > Tax Number/Steuernummer: 048/100/00053
> >> > VAT-Ident-Number/Ust.-ID: DE 199331235
> >> > DIN EN ISO 9001 certified
> >> > Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
> >> > Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> >> > E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
> >> > Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
> >> > die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> >> > The information in this e-mail is intended for the named recipients
> >> > Mapbender_users mailing list
> >> > Mapbender_users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Molkenmarkt 30
> > Germany
> > RapidEye AG
> > Molkenmarkt 30
> > Germany
Molkenmarkt 30
Germany
RapidEye AG
Molkenmarkt 30
Germany
More information about the Mapbender_users mailing list
