[Mapbender-users] MB 2.5: Problems with legends in pdf-print using mapserver's agg
Michael Schulz mschulz at webgis.de
Mon Mar 2 11:57:12 EST 2009
the problem with 24bit rendering is, that mapserver publishes that as
"image/png;mode=24bit" in the wms getcapabilities if you don't define
a special outputformat. So, when you have set image/png as
image-format in mapbender and you get a 24bit png back everything is
perfect.
Have you tried setting $unlink=false in printPDF.conf and then examine
the temporary images while generating the pdf output? I am not sure,
if this has impact on the legend images, but it could be worth a try.
Cheers, Michael
2009/3/2 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
> Hi Michael,
> sorry I don't really understand your hint :-(
> At the moment I use (wms-gui-settings): "image/png"
> But there is no difference between "image/png" and "image/png; mode=24bit".
> Only the settings in the mapfile determine the outputformat. So the following always generates a 8bit output. In this case, the printig of the picture in the legend is okay, but the quality of the map is very very poor.
> # 8 Bit Farbe
> OUTPUTFORMAT
>    NAME 'AGG_Q'
>    DRIVER AGG/PNG
>    IMAGEMODE RGB
>    FORMATOPTION "QUANTIZE_FORCE=ON"
>    FORMATOPTION "QUANTIZE_DITHER=OFF"
>    FORMATOPTION "QUANTIZE_COLORS=256"
> END
> So I want a map with 24bit color.
> Please: Could you give me some more hints?
> What shall I use ? "image/png" or "image/png; mode=24bit" in wms-settings?
> What settings in the mapfile should be done in this case ?
> regards
> Herbert Schönhammer
>>-----Ursprüngliche Nachricht-----
>>Von: mapbender_users-bounces at lists.osgeo.org
>>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>>von Michael Schulz
>>Gesendet: Montag, 2. März 2009 14:39
>>An: Mapbender User List
>>Betreff: Re: [Mapbender-users] MB 2.5: Problems with legends
>>Hello Mr. Schönhammer,
>>are you using imagemode "image/png;24bit mode" for this service in
>>Mapbender? Then this could be the problem, because printPDF sets the
>>imageformat for the maps and the legend icons to image/png. Then maybe
>>your customized outputformat isn't used anymore... In the GUI the
>>imageformats are used as defined in gui wms settings.
>>Chees, Michael Schulz
>>> Hi list,
>>> I have a new strange problem with pdf-print in Mapbender 2.5.
>>> Lines should be rendered with rounded linejoins. So I'm
>>using mapserver agg
>>> - renderer with an outputformat defined like:
>>> OUTPUTFORMAT
>>>    ##NAME png
>>>    ##DRIVER "GD/PNG"
>>>    MIMETYPE "image/png"
>>>    NAME 'AGGA'
>>>    DRIVER AGG/PNG
>>>    EXTENSION PNG
>>>    IMAGEMODE RGBA
>>>    TRANSPARENT ON
>>> END
>>> Things are done well
>>> in the map
>>> and in the legend of the gui.
>>> Things are going wrong in printing the legend in pdf-print.
>>> The legend picture is drawn with a black background. So the
>>text of the
>>> legend is not readable anymore. (Please see examples in the appendix)
>>> Until now I used gd-driver. With gd-driver all things are
>>going right.
>>> The background of the legend picture is defined transparent.
>>So the same
>>> legend picture my be used in different guis (with different
>>> background-color) and in pdf-Print.
>>> LEGEND
>>>   STATUS ON
>>>   KEYSIZE 298 398
>>>   KEYSPACING 10 1
>>>   LABEL
>>>     TYPE TRUETYPE
>>>     FONT "verdana"
>>>     SIZE 8
>>>     POSITION lc
>>>   END # END LABEL
>>>   TRANSPARENT ON
>>>   IMAGECOLOR 255 255 255
>>> END   #LEGEND
>>> I'm not able to detect any difference in the pictures
>>produced by gd or by
>>> agg. In all tools (even photo-editors) the background is displayed
>>> transparent. Only in mapbender pdf-print the background is
>>displayed in
>>> black. So I think, the solution could be in pdf-print ?
>>> Has anybody observed similar problems ?
>>> Has anybody a tipp ?
>>> Thanks a lot
>>> Herbert Schönhammer
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>Michael Schulz
>>in medias res
>>Gesellschaft für Informationstechnologie mbH
>>In den Weihermatten 66
>>79108 Freiburg
>>Tel  +49 (0)761 556959-5
>>Fax +49 (0)761 556959-6
>>http://www.webgis.de / http://www.zopecms.de
>>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_users mailing list
