[Mapbender-users] Mapbender 2.5 - Internationalization - "Locale could not be set. Language ID: 'de'"
david.mueller at kaiserslautern.de david.mueller at kaiserslautern.de
Mon May 4 03:18:07 EDT 2009
Hello List,
i've got a problem with the default language parameter in my
mapbender.conf.
I edited the following section:
# Internationalization
define("USE_I18N", true);  // requires gettext for PHP.
                                          // If "false", LANGUAGE is set to
english
define("LANGUAGE", "de");   // only available if USE_I18N is "true".
                                          // "en", "de", "bg", "gr", "nl",
"it", es"
In my Mapbender 2.5 Installation the language translation /
internationalization doesn't work.
I get this error in the logfiles:
2009.05.04, 08:40:41,ERROR: Locale could not be set. Language ID: 'de'
All the GUIS are shown in englisch, not in german, like i suggested.
My System is a Windows 2003 Server Standard with the ms4w Apache Web Server
and Mapbender 2.5 installed.
How could the language problem be solved? Any suggestions?
Thanks!
Mit freundlichem Gruß
i.A. David Müller
Stadtverwaltung Kaiserslautern
Referat Stadtentwicklung
Stabsstelle Graphische Datenverarbeitung
Willy-Brandt-Platz 1
67653 Kaiserslautern
E-Mail: david.mueller at kaiserslautern.de
Internet:  www.kaiserslautern.de
Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
http://www.kaiserslautern.de/aktuelles
More information about the Mapbender_users mailing list
