AW: [Mapbender-users] Mapbender 2.5 - Internationalization - "Locale could not be set. Language ID: 'de'"
Manns, Marc manns at str.de
Tue May 5 06:05:21 EDT 2009
does your php installation support
gettext?
You can check it via phpinfo
if not you are not be able to to use I118N!
regards Marc
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org
[mailto:mapbender_users-bounces at lists.osgeo.org]Im Auftrag von
david.mueller at kaiserslautern.de
Gesendet: Montag, 4. Mai 2009 09:18
An: mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] Mapbender 2.5 - Internationalization -
Hello List,
i've got a problem with the default language parameter in my
mapbender.conf.
I edited the following section:
# Internationalization
define("USE_I18N", true);  // requires gettext for PHP.
                                          // If "false", LANGUAGE is set to
english
define("LANGUAGE", "de");   // only available if USE_I18N is "true".
                                          // "en", "de", "bg", "gr", "nl",
"it", es"
In my Mapbender 2.5 Installation the language translation /
internationalization doesn't work.
I get this error in the logfiles:
2009.05.04, 08:40:41,ERROR: Locale could not be set. Language ID: 'de'
All the GUIS are shown in englisch, not in german, like i suggested.
My System is a Windows 2003 Server Standard with the ms4w Apache Web Server
and Mapbender 2.5 installed.
How could the language problem be solved? Any suggestions?
Thanks!
Mit freundlichem Gruß
i.A. David Müller
Stadtverwaltung Kaiserslautern
Referat Stadtentwicklung
Stabsstelle Graphische Datenverarbeitung
Willy-Brandt-Platz 1
67653 Kaiserslautern
E-Mail: david.mueller at kaiserslautern.de
Internet:  www.kaiserslautern.de
Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
http://www.kaiserslautern.de/aktuelles
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
