Antw: [Mapbender-users] Mapbender 2.5 - Gui-Element: "setBackground"
Ronald Woita Ronald.Woita at rostock.de
Fri May 8 06:33:12 EDT 2009
there's no need to configure the map file for this module.
Did you set *every* hidden service to 'select_default' ?
I don't have any problems using the background module within version 2.5, but I seem to remember that I got a similar problem in earlier times.
I think I run the set_sequences script on my database at that time.
Ronald
>>> david.mueller at kaiserslautern.de 08.05.2009 11:43 >>>
hi,
yes it's marked as 'select default'.
it's working, if i set one wms to 'hidden'.
how do i have to configure the wms's, if i want to use more than one wms in
de the "setBackground" modul?
When i configure two ore more wms to 'hidden' the names are shown in the
selectlist, but there's no map loading, when i select another wms than the
default one.
must there something be configured in the .map files, too?
thanks for your help
mapbender_users-bounces at lists.osgeo.org schrieb am 08.05.2009 09:56:17:
> did you mark the wms as 'select default' in gui settings ?
> Ronald
> >>> david.mueller at kaiserslautern.de 08.05.2009 09:16 >>>
> Hello List,
> i've got a problem with the GUI-Element "setBackground".
> I've made the following steps as mentioned in the mapbender wiki.
> - set the "setBackground" ON/OFF to 1 in my GUI
> - set my wms in the "wms gui settings" to "hidden"
> results in:
> - in the gui the selectbox is shown and filled with my "hidden"- WMS.
> - but there's no reaction, when i select the wms, the mapframe stays
white.
> - if i set a second wms to "hidden", it also appears in the selectbox,
but
> there's no reaction in the mapframe, when i switch wms.
> Has there to be any other parameter to be mentioned or edited?
> Is there somebody, who has successfully integrated this module?
> thanks!
> Mit freundlichem Gruß
> i.A. David Müller
> Stadtverwaltung Kaiserslautern
> Referat Stadtentwicklung
> Stabsstelle Graphische Datenverarbeitung
> Willy-Brandt-Platz 1
> 67653 Kaiserslautern
> E-Mail: david.mueller at kaiserslautern.de
> Internet:  www.kaiserslautern.de
> Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
> http://www.kaiserslautern.de/aktuelles
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
