Antw: [Mapbender-users] Mapbender 2.5 - Gui-Element: "setBackground"
david.mueller at kaiserslautern.de david.mueller at kaiserslautern.de
Mon May 11 10:24:40 EDT 2009
i'm using Mapbender 2.5.
it seems to be a problem with the "dynamicOverview" modul.
i've set my wms-0 to hidden and as default wms in my gui.
a wms-1 is also set to hidden.
In the setbackground modul these two wms-0 & wms-1 are available.
The setbackground modul works fine, if i have the "dynamicOverview" modul
deactivated.
If i have the "dynamicOverview" activated, the "setBackground" works also,
but the default wms-0 is always activated. It should be deactivated, when i
select my wms-1 in "setBackground".
Instead wms-1 is drawn over wms-0.
wms-0 is configured in moduls "overview" and "dynamicOverview" as
wms-index.
It seems, that the "dynamicOverview" makes wms-0 always available.
Has anybody configured both moduls in one gui?
Mit freundlichem Gruß
i.A. David Müller
Stadtverwaltung Kaiserslautern
Referat Stadtentwicklung
Stabsstelle Graphische Datenverarbeitung
Willy-Brandt-Platz 1
67653 Kaiserslautern
E-Mail: david.mueller at kaiserslautern.de
Internet:  www.kaiserslautern.de
mapbender_users-bounces at lists.osgeo.org schrieb am 08.05.2009 15:36:17:
> Hi,
> normally the setBackgroud does not make trouble.
> What mapbender Version do you use?
> Is your GUI available?
> I tried it with Mapbender 2.6 and it still works in gui. Have a look at
> your Mapbender in gui "gui". Does the Modul work in this gui? What does
> firebug say.
> best regards astrid
> david.mueller at kaiserslautern.de schrieb:
> > hi,
> > yes it's marked as 'select default'.
> > it's working, if i set one wms to 'hidden'.
> > how do i have to configure the wms's, if i want to use more than one
wms in
> > de the "setBackground" modul?
> > When i configure two ore more wms to 'hidden' the names are shown in
the
> > selectlist, but there's no map loading, when i select another wms than
the
> > default one.
> > must there something be configured in the .map files, too?
> > thanks for your help
> > mapbender_users-bounces at lists.osgeo.org schrieb am 08.05.2009 09:56:17:
> >> did you mark the wms as 'select default' in gui settings ?
> >> Ronald
> >>>>> david.mueller at kaiserslautern.de 08.05.2009 09:16 >>>
> >> Hello List,
> >> i've got a problem with the GUI-Element "setBackground".
> >> I've made the following steps as mentioned in the mapbender wiki.
> >> - set the "setBackground" ON/OFF to 1 in my GUI
> >> - set my wms in the "wms gui settings" to "hidden"
> >> results in:
> >> - in the gui the selectbox is shown and filled with my "hidden"- WMS.
> >> - but there's no reaction, when i select the wms, the mapframe stays
> > white.
> >> - if i set a second wms to "hidden", it also appears in the selectbox,
> > but
> >> there's no reaction in the mapframe, when i switch wms.
> >> Has there to be any other parameter to be mentioned or edited?
> >> Is there somebody, who has successfully integrated this module?
> >> thanks!
> >> i.A. David Müller
> >> Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
> >> http://www.kaiserslautern.de/aktuelles
> >> _______________________________________________
> >> Mapbender_users mailing list
> >> Mapbender_users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> Kompaktseminar zum Thema:
> ETRS 89 - Das neue Bezugssystem
> 19. Mai in Bonn
> http://www.wheregroup.com/etrs89_das_neue_bezugssystem
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Siemensstraße 8
>  53121 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 19
>  Fax: +49(0)228 90 90 38 - 11
>  astrid.emde at wheregroup.com
>  www.wheregroup.com
>  Amtsgericht Bonn, HRA 6788
>  Komplementärin:
>  WhereGroup Verwaltungs GmbH
>  vertreten durch:
>  Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
