Antw: [Mapbender-users] Mapbender 2.5 - Gui-Element: "setBackground"
david.mueller at kaiserslautern.de david.mueller at kaiserslautern.de
Tue May 12 03:00:32 EDT 2009
great, that's it!
thanks for your help!
Mit freundlichem Gruß
i.A. David Müller
Stadtverwaltung Kaiserslautern
Referat Stadtentwicklung
Stabsstelle Graphische Datenverarbeitung
Willy-Brandt-Platz 1
67653 Kaiserslautern
Tel  0631 - 3654043
E-Mail: david.mueller at kaiserslautern.de
Internet:  www.kaiserslautern.de
mapbender_users-bounces at lists.osgeo.org schrieb am 12.05.2009 07:34:34:
> hi,
> ok- now I seem to remember...
> Put this code into 'mod_dynamicOverview.php'
> at the end of the function 'mod_dynamicOverviewSetVisibility()'
> function mod_dynamicOverviewSetVisibility(frameName){
>    var arrayTargets = mod_dynamicOverview_target.split(",");
>    if(mod_dynamicOverviewSwitch && frameName == arrayTargets[1]){
>       wms[mod_dynamicOverview_wmsIndex].gui_wms_visible =
> mod_dynamicOverviewSwitch;
>    // HINZUFÜGEN >
>    if(parent.document.setBackground.mod_setBackground_list.
> options[parent.document.setBackground.mod_setBackground_list.
> selectedIndex].value != mod_dynamicOverview_wmsIndex) {
>       wms[mod_dynamicOverview_wmsIndex].gui_wms_visible = 0;
>    else {
>       for(var i = 0; i < parent.document.setBackground.
> mod_setBackground_list.options.length; i++) {
>          if(i != mod_dynamicOverview_wmsIndex) {
>             wms[i].gui_wms_visible = 0;
>    // < HINZUFÜGEN
> Ronald
> >>> david.mueller at kaiserslautern.de 11.05.2009 16:24 >>>
> Hi,
> i'm using Mapbender 2.5.
> it seems to be a problem with the "dynamicOverview" modul.
> i've set my wms-0 to hidden and as default wms in my gui.
> a wms-1 is also set to hidden.
> In the setbackground modul these two wms-0 & wms-1 are available.
> The setbackground modul works fine, if i have the "dynamicOverview" modul
> deactivated.
> If i have the "dynamicOverview" activated, the "setBackground" works
also,
> but the default wms-0 is always activated. It should be deactivated, when
i
> select my wms-1 in "setBackground".
> Instead wms-1 is drawn over wms-0.
> wms-0 is configured in moduls "overview" and "dynamicOverview" as
> wms-index.
> It seems, that the "dynamicOverview" makes wms-0 always available.
> Has anybody configured both moduls in one gui?
> i.A. David Müller
> mapbender_users-bounces at lists.osgeo.org schrieb am 08.05.2009 15:36:17:
> > Hi,
> > normally the setBackgroud does not make trouble.
> > What mapbender Version do you use?
> > Is your GUI available?
> > I tried it with Mapbender 2.6 and it still works in gui. Have a look at
> > your Mapbender in gui "gui". Does the Modul work in this gui? What does
> > firebug say.
> > best regards astrid
> > david.mueller at kaiserslautern.de schrieb:
> > > hi,
> > > yes it's marked as 'select default'.
> > > it's working, if i set one wms to 'hidden'.
> > > how do i have to configure the wms's, if i want to use more than one
> wms in
> > > de the "setBackground" modul?
> > > When i configure two ore more wms to 'hidden' the names are shown in
> the
> > > selectlist, but there's no map loading, when i select another wms
than
> the
> > > default one.
> > > must there something be configured in the .map files, too?
09:56:17:
> > >> did you mark the wms as 'select default' in gui settings ?
> > >> Ronald
> > >>>>> david.mueller at kaiserslautern.de 08.05.2009 09:16 >>>
> > >> Hello List,
> > >> i've got a problem with the GUI-Element "setBackground".
> > >> I've made the following steps as mentioned in the mapbender wiki.
> > >> - set the "setBackground" ON/OFF to 1 in my GUI
> > >> - set my wms in the "wms gui settings" to "hidden"
> > >> results in:
> > >> - in the gui the selectbox is shown and filled with my "hidden"-
WMS.
> > >> - but there's no reaction, when i select the wms, the mapframe stays
> > > white.
> > >> - if i set a second wms to "hidden", it also appears in the
selectbox,
> > > but
> > >> there's no reaction in the mapframe, when i switch wms.
> > >> Has there to be any other parameter to be mentioned or edited?
> > >> Is there somebody, who has successfully integrated this module?
> > >> thanks!
> > >> i.A. David Müller
> > >> Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
> > >> http://www.kaiserslautern.de/aktuelles
> > >> _______________________________________________
> > >> Mapbender_users mailing list
> > >> Mapbender_users at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Mit freundlichen Grüßen
> > Astrid Emde
> > Kompaktseminar zum Thema:
> > ETRS 89 - Das neue Bezugssystem
> > 19. Mai in Bonn
> > http://www.wheregroup.com/etrs89_das_neue_bezugssystem
> >  Astrid Emde
> >  WhereGroup GmbH & Co.KG
> >  Siemensstraße 8
> >  53121 Bonn
> >  Germany
> >  Fon: +49(0)228 90 90 38 - 19
> >  Fax: +49(0)228 90 90 38 - 11
> >  astrid.emde at wheregroup.com
> >  www.wheregroup.com
> >  Amtsgericht Bonn, HRA 6788
> >  Komplementärin:
> >  WhereGroup Verwaltungs GmbH
> >  vertreten durch:
> >  Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
