[SOLVED] Re: Re: [Mapbender-users] GetFeatureInfo on WMS
Michael Schulz mschulz at webgis.de
Thu Oct 1 03:58:23 EDT 2009
Hi Robert,
thanks for bringing this up. I haven't made up my mind yet, what the
correct solution would be. We'd need to know how the mapservers handle
this case. Some facts for a discussion:
- the layer parameter is empty because mapbender respects the scale
settings, that is correct.
- Mapserver throws an exception when the layers parameter is empty
(and the mapfile contains no DEFAULT layers)
Should Mapbender respect the min/maxscale settings also for querylayers?
Still thinking... Michael
2009/10/1 Robert Walter <robert-walter at gmx.de>:
> Hi Michael, hi list,
> the problem is, that the url in the featureInfoTunnel request contains no LAYERS parameter, when the layer is invisible because of the maxScale setting. That is why the mapserver throws a ServiceException.
> Now I have a workaround for my problem. I have changed the "javascript/mod_featureInfoTunnel.php" near line 82.
> 81 ...
> 82 mb_ajax_post(path, {'url':currentRequest},function(js_code,status){
> 83     var isServiceException = js_code.search(/<ServiceException/)
> 84     if(js_code && isServiceException == -1){
> 85         if(featureInfoLayerPopup == 'true'){
> 86             ...
> Not the nicest code but it works. Now I can use the maxScale setting in conjunction with the featureInfoTunnel module without any error message.
> Thanks for your support.
> Greetings Robert
> Hi Robert,
> I wonder whether UMN Mapserver in this case throws an error at all
> ...? Hmm. Looking at your error message, it gets thrown in
> msLoadWMSGetMapParams. I don't think this function already takes the
> scale into account, it just collects the layers that are given in the
> request and checks whether they exist. When drawing the map it just
> omits them, I guess the same should happen for getFI. I am not totally
> sure about this and happy to be told the opposite.
> Could you check your getFeatureInfo Request whether there are any
> other things happening to the layers or querylayers parameter? Are you
> using grouped layers?
> Cheers, Michael
> 2009/9/30 Robert Walter <robert-walter at gmx.de>:
>> Hi Michael,
>> thanks for your answer.
>> Setting "ficheckbox" to false works for switching the layer manually off. But when
> the setting maxScale in wms settings is set and the layer is invisible because of
> the mapscale, the featureinfo still shows the error.
>> And when I surf through the mapbender application in the wiki-gallery, obviously
> no one uses the maxscale setting in conjunction with the featureinfo tool. So this
> seems to be a known problem.
>> Greetings Robert
>> Hi Robert,
>> as far as I can see it is true, that Mapbender currently doesn't check
>> whether a queryable layer is also visible, and if not visible
>> automatically also disables it's queryability.
>> I think we had some discussion about that issue in the past, because
>> there are use-cases, when you exactly want a layer to be queryable but
>> not visible. The outcome is, that when using treegde with element_var
>> "ficheckbox" set to true, it is up to the user to en-/disable
>> visbility/queryability in the tree by means of seperate checkboxes. If
>> "ficheckbox" is set to false, you'll only get one checkbox per layer,
>> that toggles visbility/queryability combined on or off. So maybe
>> thats's what you're looking for.
>> Cheers, Michael
>>> Hi,
>>> I'm using Mapbender 2.6 with a modified copy of gui2. The error message appears if
>> a wms layer is set to invisible or invisible because of it's scale and the
>> featureinfo checkbox is still enabled. I think there should be a dependency
>> between the visibility of a layer and the possibility to make featureinfo
>> requests.
>>> Greetings Robert
>>> Hi,
>>> could you give us more information on what version of mapbender you
>>> are using? Is this error happening in a standard gui or in a self-made
>>> gui?
>>> Greetings, Michael
>>> 2009/9/28 Robert Walter <robert-walter at gmx.de>:
>>>> Hi list,
>>>> I have a problem with getfeatureinfo-requests on WMS-layers. In the mapfile of the
>>> wms a template for each layer is defined. I use the featureinfotunnel with the new
>>> popup-module.
>>>> When the wms is enabled and visible in Mapbender the getfeatureinfo-request shows
>>> the correct info. But when the wms is turned off in treegde-module or the
>>> wms-layer is invisible because of its scale, the getfeatureinfo shows the
>>> following error:
>>>> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
>>>> <!DOCTYPE ServiceExceptionReport SYSTEM
>>> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
>>>> <ServiceExceptionReport version="1.1.1">
>>>> <ServiceException code="LayerNotDefined">
>>>> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS
>>> parameter.
>>>> </ServiceException>
>>>> </ServiceExceptionReport>
>>>> What can I do, to avoid this behaviour. When there is no object visible, the
>>> getfeatureinfo-request should return no result and must not open the popup.
>>>> Greeting RW
>>>> Jetzt kostenlos herunterladen: Internet Explorer 8 und Mozilla Firefox 3.5 -
>>>> sicherer, schneller und einfacher! http://portal.gmx.net/de/go/atbrowser
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Besuchen Sie uns auf der INTERGEO 2009: 22.09. - 24.09.2009 in Karlsruhe;
>>> Halle 1, Stand 1.417
>>> Aufwind durch Wissen!
>>> Qualifizierte Open Source Schulungen bei der
>>> http://www.foss-akademie.de/
>>> Michael Schulz
>>> in medias res
>>> Gesellschaft für Informationstechnologie mbH
>>> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
>>> Schwimmbadstraße 2
>>> D-79100  Freiburg i. Br.
>>> Tel:  +49 (0)761 705798-102
>>> Tel:  +49 (0)761 705798-0
>>> Fax: +49 (0)761 705798-09
>>> http://www.webgis.de / http://www.zopecms.de
>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>>> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
>>> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
>> Michael Schulz
>> in medias res
>> Schwimmbadstraße 2
> Michael Schulz
> in medias res
> Schwimmbadstraße 2
> Neu: GMX Doppel-FLAT mit Internet-Flatrate + Telefon-Flatrate
> für nur 19,99 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
Michael Schulz
in medias res
Schwimmbadstraße 2
More information about the Mapbender_users mailing list
