[Mapbender-users] Select EPSG
Michael Schulz mschulz at webgis.de
Thu Oct 1 05:18:02 EDT 2009
Hi Sven,
the problem is that UMN Mapserver can be configured to serve a lot of
SRS'es, but only exposes EPSG:4326 and the SRS of the map-object with
bounding-boxes in the getCap-XML. Only these SRS that have BBOX
information are taken from mapbender to fill the EPSG-Select list of
the first wms of a gui in edit GUI-WMS settings.
So far the only way is to change the getCap-XML manually and add bbox
entries for each SRS you want to be able to choose from and then load
the getCap locally.
Cheers, Michael
2009/10/1 Sven Böhme <boehme at supportgis.de>:
> Hi Frank,
> thank you for your answer. But I try to change the EPSG in the
> administartion GUI (WMS GUI Einstellungen /serttings). There you can choose
> the EPSG  for the WMS on top. And there are only the initial EPSG codes. But
> I try to use e.g. Germany WMS as background WMS and another WMS
> (EPSG:31468). But I can´t change the EPSG of the Germany WMS and the other
> WMS doesn´t support 4326 or 31467.
> Sven
> Jäger schrieb:
> -----Original Message-----
> From: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of
> Sven Böhme
> Sent: Thursday, October 01, 2009 9:28 AM
> To: Mapbender User List
> Subject: [Mapbender-users] Select EPSG
> Hi,
> in the WMS GUI settings I can choose the EPSG. But I can only
> chosse between two EPSG code, although the WMS supports more
> than two codes.
> How can I use e.g. EPSG:31468 for Germany WMS?
> Thanks
> Sven
> Hi,
> /php/mod_changeEPSG.php doesn't look at the WMS.
> Available EPSG-Codes are hard coded. I changed it to my needs:
> <form action="<?php echo $self;  ?>" method='POST'>
> <select class='epsg' name='epsg' onchange='mod_changeEPSG()'>
> <option value="">undefined</option>
> <option value="EPSG:31467">Gau&szlig;-Kr&uuml;ger 3 (31467)</option>
> <option value="EPSG:25832">ETRS89/UTM (25832)</option>
> <!-- <option value="EPSG:4326">Geogr. Koord.(4326)</option> -->
> </select>
> "EPSG:4326" doesn't work with minscale/maxscale and "setScaleHint" in a GUI.
> Frank
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Dipl.-Geogr. Sven Böhme
> CPA Systems GmbH
> Grantham-Allee 2-8
> D-53757 Sankt Augustin
> Tel.: +49 (0) 2241 / 25 94 – 24
> Fax.: +49 (0) 2241 / 25 94 - 29
> www.cpa-systems.de
> Handelsregister:
> HRB 9706, Amtsgericht Siegburg
> Geschäftsführer:
> Dr.-Ing. habil. Christoph Averdung
> Dr.-Ing. René Thiele
> Dr.-Ing. Matthias Ellsiepen
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
