Antw: Re: Fw: Re: [Mapbender-users] GUIs in mapbender 2.6 after login not shown
Ronald Woita Ronald.Woita at rostock.de
Wed Oct 14 02:43:00 EDT 2009
I installed mapbender in PostGreSQL 8.3.8 and got no problems.
Did you install mapbender with the new install script ?
I got a similar behaviour if I created the database manually and forgot
to put in the update scripts ( from 2.5 to 2.6)
Ronald
>>> bird_harbin at operamail.com 14.10.2009 01:51 >>>
still no gui's.
Which version of postgresql are people running with mapbender 2.6 ?
May be all users run 8.1.x or 8.2.x ?
I think it might be a bug but we need to verify.
Rgds
Bird
> ----- Original Message -----
> From: "Norman Rauthe" <rauthe at zadi.de>
> To: "Mapbender User List" <mapbender_users at lists.osgeo.org>
> Subject: Re: Fw: Re: [Mapbender-users] GUIs in mapbender 2.6 after
login not	shown
> Date: Tue, 13 Oct 2009 14:31:19 +0200
> Hi Bertil,
> you're right, you have to use GRANT ALL ON DATABASE mapbender TO
userXY;
> Bertil Miller schrieb:
> > I am on a windows system:
> > I use from the windows menu:
> > psql to 'postgres'
> > (PostgreSQL interactive terminal connected to the postgres
database)
> > then this prompt shows up:
> > Welcome to psql 8.3.8, the PostgreSQL interactive terminal.
> > Type:  \copyright for distribution terms
> >        \h for help with SQL commands
> >        \? for help with psql commands
> >        \g or terminate with semicolon to execute query
> >        \q to quit
> > Warning: Console code page (437) differs from Windows code page
(1252)
> >          8-bit characters might not work correctly. See psql
reference
> >          page "Notes for Windows users" for details.
> > postgres# GRANT ALL ON mapbender TO postgres;
> > still not what are the commands to be entered ???
> > or do I have to enter
> > GRANT ALL PRIVILEGES ON DATABASE mapbender TO postgres    ???
> > Please advive.
> > Thank you!
> > Best regards
> > Bird  ----- Original Message -----
> > Subject: Re: [Mapbender-users] GUIs in mapbender 2.6 after login
not shown
> > Date: Sun, 11 Oct 2009 20:26:12 +0200
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Surf the Web in a faster, safer and easier way:
Download Opera 9 at http://www.opera.com
Powered by Outblaze
More information about the Mapbender_users mailing list
