[Mapbender-users] GUIs in mapbender 2.6 visible when updating with sql-Scripts from 2.5 to 2.6 after login not shown
Bertil Miller bird_harbin at operamail.com
Wed Oct 14 07:36:53 EDT 2009
Yes, this was the reason !
so the update order I used was the following:
update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
update_2.5..1rc1_to_2.5.1_pgsql_UTF-8.sql
update_2.5.1_to_2.6.rc1_pgsql_UTF-8.sql
update_2-6-rc1_to_2.6_pgsql_UTF-8.sql
Thank you so much !
Rgds
Bird
> ----- Original Message -----
> From: "Ronald Woita" <Ronald.Woita at rostock.de>
> To: mapbender_users at lists.osgeo.org
> Subject: Antw: Re: Fw: Re: [Mapbender-users] GUIs in mapbender 2.6	after login not shown
> Date: Wed, 14 Oct 2009 08:43:00 +0200
> Hi,
> I installed mapbender in PostGreSQL 8.3.8 and got no problems.
> Did you install mapbender with the new install script ?
> I got a similar behaviour if I created the database manually and forgot
> to put in the update scripts ( from 2.5 to 2.6)
> Ronald
> >>> bird_harbin at operamail.com 14.10.2009 01:51 >>>
> still no gui's.
> Which version of postgresql are people running with mapbender 2.6 ?
> May be all users run 8.1.x or 8.2.x ?
> I think it might be a bug but we need to verify.
> Rgds
> Bird
> > From: "Norman Rauthe" <rauthe at zadi.de>
> > To: "Mapbender User List" <mapbender_users at lists.osgeo.org>
> > Subject: Re: Fw: Re: [Mapbender-users] GUIs in mapbender 2.6 after
> login not	shown
> > Date: Tue, 13 Oct 2009 14:31:19 +0200
> > Hi Bertil,
> > you're right, you have to use GRANT ALL ON DATABASE mapbender TO
> userXY;
> > Bertil Miller schrieb:
> > > I am on a windows system:
> > > I use from the windows menu:
> > > psql to 'postgres'
> > > (PostgreSQL interactive terminal connected to the postgres
> database)
> > > then this prompt shows up:
> > > Welcome to psql 8.3.8, the PostgreSQL interactive terminal.
> > > Type:  \copyright for distribution terms
> > >        \h for help with SQL commands
> > >        \? for help with psql commands
> > >        \g or terminate with semicolon to execute query
> > >        \q to quit
> > > Warning: Console code page (437) differs from Windows code page
> (1252)
> > >          8-bit characters might not work correctly. See psql
> reference
> > >          page "Notes for Windows users" for details.
> > > postgres# GRANT ALL ON mapbender TO postgres;
> > > still not what are the commands to be entered ???
> > > or do I have to enter
> > > GRANT ALL PRIVILEGES ON DATABASE mapbender TO postgres    ???
> > > Please advive.
> > > Thank you!
> > > Best regards
> > > Bird  ----- Original Message -----
> > > Subject: Re: [Mapbender-users] GUIs in mapbender 2.6 after login
> not shown
> > > Date: Sun, 11 Oct 2009 20:26:12 +0200
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Surf the Web in a faster, safer and easier way:
> Download Opera 9 at http://www.opera.com
> Powered by Outblaze
Powered by Outblaze
More information about the Mapbender_users mailing list
