[Mapbender-users] Create points with a geoserver WFS-T
Daniel Grum daniel.grum at unibw.de
Thu Oct 15 09:46:18 EDT 2009
Sebastian Krohn-Grimberghe schrieb:
> Hello,
> Daniel Grum wrote:
>> Do I hve to delete all the Triggers in the data tables and create this
>> new, if I have changed the trigger function?
> No, you just have to replace the trigger function.
>> I changed the trigger function in that version with the numer of
>> differnet loops, but... the error message after changing the function
>> and reloading my geoserver was the same.
> If this does not work I cannot help you with this, except for giving you the
> advice to test the select statements and change them until they return the
> correct results. It works fine with my data, but of course I do not know
> anything about the data you are using.
> Best regards,
> Sebastian
> Entwicklung
> IP SYSCON GmbH
> Tiestestraße 16-18
> D-30171 Hannover
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Thank you for the help.
I will solve it in the next days I think....
More information about the Mapbender_users mailing list
