[Mapbender-users] Problems with my initial view (BBOX)
Michael Schulz mschulz at webgis.de
Wed Oct 21 15:50:54 EDT 2009
Hi Lluís,
you need to have the module setBBOX enabled for the GUI you want to
set a start extent with mb_myBBOX. Have you checked that this module
is present an enabled in your GUI? See here:
http://www.mapbender.org/Mb_mybbox
If it still not working, please give us teh Mapbender Version you're
working with. I think to recall there was a MB 2.5 Version that had a
typo in ./conf/session.conf wrt. to the mb_myBBOX parameter, but I am
not sure...
HTH, michael
2009/10/21 Lluís Vicens <lluis at sigte.udg.es>:
> Hi,
> I have a little problem (well, in fact this is one of my problems!) that I
> tried to solve for myself reading the wiki (mapbender documentation) as well
> as some of the mailing list archives but I cannot find a solution. How can I
> define my initial extent with mapbender? I tried several options regarding
> to the BBOX even I put manually the parameter &mb_myBBOX= into the URL but
> it doesn't work :(
> I want to fix my initial view based on EPSG:4326 where minx,miny,maxx,maxy
> are 2.4354,41.7065,3.1989,42.2430. My base cartography WMS is
> "http://shagrat.icc.es:80/lizardtech/iserv/ows?" and if I check (firebug)
> which is the request that mapbender is doing to this server the result is
> http://shagrat.icc.cat/lizardtech/iserv/ows?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=sat250m&STYLES=&SRS=EPSG:4326
> &BBOX=-24.5,27.14789603960396,34.5,75.85210396039604&WIDTH=808&HEIGHT=667&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE
> &EXCEPTIONS=application/vnd.ogc.se_xml&
> ¿How could I define my initial bbox?
> Thanks in advance for your help and sorry if this is a question answered so
> many times before... :-[
> Regards,
> Lluís
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
