[Mapbender-users] GetFeatureInfo on WMS
Michael Schulz mschulz at webgis.de
Wed Sep 30 05:16:54 EDT 2009
Hi Robert,
as far as I can see it is true, that Mapbender currently doesn't check
whether a queryable layer is also visible, and if not visible
automatically also disables it's queryability.
I think we had some discussion about that issue in the past, because
there are use-cases, when you exactly want a layer to be queryable but
not visible. The outcome is, that when using treegde with element_var
"ficheckbox" set to true, it is up to the user to en-/disable
visbility/queryability in the tree by means of seperate checkboxes. If
"ficheckbox" is set to false, you'll only get one checkbox per layer,
that toggles visbility/queryability combined on or off. So maybe
thats's what you're looking for.
Cheers, Michael
2009/9/30 Robert Walter <robert-walter at gmx.de>:
> Hi,
> I'm using Mapbender 2.6 with a modified copy of gui2. The error message appears if a wms layer is set to invisible or invisible because of it's scale and the featureinfo checkbox is still enabled. I think there should be a dependency between the visibility of a layer and the possibility to make featureinfo requests.
> Greetings Robert
> Hi,
> could you give us more information on what version of mapbender you
> are using? Is this error happening in a standard gui or in a self-made
> gui?
> Greetings, Michael
> 2009/9/28 Robert Walter <robert-walter at gmx.de>:
>> Hi list,
>> I have a problem with getfeatureinfo-requests on WMS-layers. In the mapfile of the
> wms a template for each layer is defined. I use the featureinfotunnel with the new
> popup-module.
>> When the wms is enabled and visible in Mapbender the getfeatureinfo-request shows
> the correct info. But when the wms is turned off in treegde-module or the
> wms-layer is invisible because of its scale, the getfeatureinfo shows the
> following error:
>> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
>> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
>> <ServiceExceptionReport version="1.1.1">
>> <ServiceException code="LayerNotDefined">
>> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS
> parameter.
>> </ServiceException>
>> </ServiceExceptionReport>
>> What can I do, to avoid this behaviour. When there is no object visible, the
> getfeatureinfo-request should return no result and must not open the popup.
>> Greeting RW
>> Jetzt kostenlos herunterladen: Internet Explorer 8 und Mozilla Firefox 3.5 -
>> sicherer, schneller und einfacher! http://portal.gmx.net/de/go/atbrowser
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Besuchen Sie uns auf der INTERGEO 2009: 22.09. - 24.09.2009 in Karlsruhe;
> Halle 1, Stand 1.417
> Aufwind durch Wissen!
> Qualifizierte Open Source Schulungen bei der
> http://www.foss-akademie.de/
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
Michael Schulz
in medias res
Schwimmbadstraße 2
More information about the Mapbender_users mailing list
