[Mapbender-users] zoom to coordinates out of a popup window
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Tue Apr 13 11:13:09 EDT 2010
I see, it must be
$_GET[]
with square brackets, not round brackets.
Thanks
Christoph
Andreas Voit schrieb:
> hallo,
> I already send the source code, I mean the line where the error occurs.
> Again:
> "$target=$_GET('target');" is the line where the error occurs. But as
> attachment I send you also the source code. I marked the line with the
> comment "<!-- HERE OCCURS THE ERROR -->".
> In the mapbender GUI I created a button to open the formular. The
> attributes in the GUI configuration: 'onclick='searchWindow =
> window.open("/form/form.php?sessionID&target=mapframe1,overview","searchWin","width=800,
> height=600, scrollbars=yes, resizable=yes");');'
> In summary it's normal formular, I have to get some values for dropdown
> list from an postgreSQL db (Bezirke). I know it is not a elegant
> solution, but it works ;)
> hope you can help me.
> cu
> Am 13.04.2010 16:21, schrieb Christoph Baudson (Wheregroup):
>> Hi Andreas,
>> thanks for your mail. Please forward the source of form.php and the line
>> where the error occured.
>> Thanks,
>> Christoph
>>> hallo,
>>> I'd like to press a button in a popup window and then it should zoom to
>>> a location.
>>> I found the tool "zoomCoords" in GUI1. But that only works if it is used
>>> in the map user interface. I want to uses it in a popup window.
>>> so it has problem to find the function "zoom", I guess it is a map
>>> specific function and is only available at the map gui.
>>> <code>
>>>     zoom(mod_zoomCoords_target[0],true, 1.0,x,y);
>>> </code>
>>> As you can see in the code example there is use a variable
>>> "mod_zoomCoords_target[0]", which I guess is "mapframe1,overview".
>>> So I tried to make a url query string to my own gui element button:
>>> <code>
>>> window.open("form.php?sessionID&target=mapframe1,overview","searchWin","width=800,
>>> height=600, scrollbars=yes, resizable=yes");');'<?php
>>> $target=$_GET('target');?>
>>> </code>
>>> In my form.php I want to save the value of target into a variable like:
>>> <code>
>>>     <?php $target=$_GET('target');?>
>>> </code>
>>> Then I get an error: Fatal error: "Function name must be a string in
>>> \mapbender\http\form\form.php"
>>> In summery I want to zoom to a location in a map, by pressing a custom
>>> button, which is in a popup window.
>>> Does anyone know a solution, I would be happy ;)
>>> cu
>>> My System
>>> Mapbender 2.6
>>> Windows XP + SP3
>>> XAMPP 1.7.3
>>> Database Postgres 8.4 + PostGIS
>>> GeoServer 2.0.1
>     Einfache Suche
> end up here checkresult($resultBezirk,$queryBezirk); ?>
>     * Bezirk * Bezirk auswählen <#>
>     * " ?> KG * Katastralgemeinde auswählen <#>
>     * Grundstücksnr Grundstücksnummer (optional) <#>
>     * Umkreis Auswahl eines Buffers indem Massenbewegung gesucht
>       werden soll (optional) <#>
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
