[Mapbender-users] Re: call Mapbender-instance with WMS-URL
Milad84 milad1984 at gmail.com
Wed Apr 14 16:14:41 EDT 2010
hi..
I followed all the instructions. I added the variable and i tried it with
login.php and index.php. nor did work.
Maybe my wms is added but I just cant see it? But I assume that the wms
should appear in the left-hand tree aswell. Am I right?
Michael Schulz wrote:
> Milad,
> if you can't find the element var "loadFromSession" you'll have to set
> it using the edit gui form. Tto check/set the element var click on the
> link of the element id "loadwmc" - not the checkbox.
> I am not 100% sure, but i think you have to use login.php not
> index.php. Try the link again, supplying a name, password, if that
> user has more than one gui assigned you need to supply the gui_id as
> well (as mb_user_myGui) and then the wms1 url, like this:
> http://localhost/mapbender26/http/frames/login.php?name=test&password=test&mb_user_myGui=gui1&
> &wms1=http%3A%2F%2Fintergeo.sdisuite.de%3A80%2Fwmsconnector%2Fgdi%2Fbrd%3Frequest%3Dgetcapabilities%26service%3Dwms
> HTH, Michael
> 2010/4/14 Milad84 <milad1984 at gmail.com>:
>> Hi,
>> well I updated mapbender to 2.6 but it still doesnt work. I try to load
>> my
>> gui1 with a wms. checked the gui and the loadWMC is enabled but I still
>> didnt find something about loadFromSession
>> my link looks as followed..
>> http://localhost/mapbender26/http/frames/index.php?&gui_id=gui1&wms1=http%3A%2F%2Fintergeo.sdisuite.de%3A80%2Fwmsconnector%2Fgdi%2Fbrd%3Frequest%3Dgetcapabilities%26service%3Dwms
>> greets
>> milad
>> View this message in context:
>> http://n2.nabble.com/call-Mapbender-instance-with-WMS-URL-tp4896325p4901984.html
>> Sent from the mapbender-users mailing list archive at Nabble.com.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Aufwind durch Wissen!
> Qualifizierte Open Source Schulungen bei der
> http://www.foss-academy.eu/
> Michael Schulz
> mschulz at webgis.de
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
View this message in context: http://n2.nabble.com/call-Mapbender-instance-with-WMS-URL-tp4896325p4903861.html
More information about the Mapbender_users mailing list
