[Mapbender-users] Re: call Mapbender-instance with WMS-URL
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Thu Apr 15 11:09:00 EDT 2010
Hi Milad,
seems like this is an issue in 2.6 only. It works in trunk. I will add a
bug fix for 2.6 tomorrow, I still have to figure out what goes wrong.
I'm able to load the WMS, but (de)selecting layers doesn't work.
Here's the complete URL, apparently you also have to add a command
"ADDWMS".
http://domain/path/frames/login.php?name=xxxx&password=xxxx&mb_user_myGui=gui1&wms1=http%3A%2F%2Fintergeo.sdisuite.de%3A80%2Fwmsconnector%2Fgdi%2Fbrd%3Frequest%3Dgetcapabilities%26service%3Dwms&COMMAND=ADDWMS
Beware that this is not an official feature of Mapbender yet, but an
undocumented feature that resulted from a workaround for a client. We
are now starting to work on a fully documented RESTful API which will
make these operations much easier in future releases.
Thanks for your patience, will get back to you soon.
Christoph
Milad84 schrieb:
> hi christoph,
> had you already time to check that on your local machine?
> thanks
> milad
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
