[Mapbender-users] Error installation mapbender 2.6.2
Karim Malhas karim at malhas.de
Sun Aug 8 08:04:57 EDT 2010
Hi Sandramp,
> The mapbender setup-checker page shows no errors and I see the login
page
> with no problems, but then, when I log in with the root user and
password
> the next page says "Internet Explorer cannot display the webpage".
Easy. The problem is that you are using Internet Explorer (just kidding of
course, but have you tried a different browser? Maybe it will display a
more descriptive error message.)
> So I am having a look at the logs and there are two main problems I see:
> 1) Everytime I try to log in, the Postgresql server log keeps saying:
Could
> not receive data from client.No connection could be made because the
target
> machine actively refused it.
This is likely the source of your problem. Did you verify that you can
access the database as the Mapbender user?
> 2) Apache error log: File does not exist:
C:/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/.ui.tabs.js,
> referer: http://localhost/mapbender/frames/login.php
> Parent: child process exited with status 255 -- Restarting
> I have searched this file and there is one ui.tabs.js file in this
> directory
> but without the "dot" in front of ui??
> I don't know where the problem lies... Is it the communication between
> server and mapbender, is it this file that is missing?? I have been
reading
> several forums but I only got more confused.
While it's certainly a problem that that extra dot is there, it should not
be causing Mapbender to fail completely like that.
Could you post more of the apache logs ? Best would be everything that
happens around the login.
> I allready tried to uninstall everything and start from the beginning
but
> with no results. Should I download different versions and try again?
Which exact version did you download?
Regards,
Karim
More information about the Mapbender_users mailing list
