[Mapbender-users] Re: Error installation mapbender 2.6.2
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Mon Aug 9 05:04:51 EDT 2010
sandramp wrote:
> Hi Karim,
> Thanks for your help. Following your advice, I have installed Firefox (is
> this one ok?? ;-)) and the message shown is (more or less, I translated it):
> Connection to the server has been restarted while the page was being loaded.
> Site is temporally not available or too busy. Try again in a few moments.
> If you cannot load any page, check the network connection of your system
> If your system or network are protected by a firewall or proxy, check that
> Firefox has permission for accessing the web.
> I thought I turned the firewall off to avoid problems, but I've checked it
> again. Now I also turned off something like "Domain Profile" and I noticed
> that the "Private Profile" is active, but Firewall is turned off.
> Maybe the answer is very simple, but how do I verify that I can access the
> database as the Mapbender user? The database including the table mb_user
> with the user "root" is there.
You can copy
tools/mapbender_setup.php
into http/tools
and call it in the browser. This script will tell you if your
installation is fine.
Christoph
> Here I post you something more from the apache logs. These are the messages
> from two different log in's
> (hopefully it is more meaningful to you than it is for me ...):
> [Sun Aug 08 22:49:53 2010] [notice] Child 2348: Starting thread to listen on
> port 80.
> [Sun Aug 08 23:01:16 2010] [error] [client 127.0.0.1] File does not exist:
> C:/Program Files/Apache Software Foundation/Apache2.2/htdocs/favicon.ico
> [Sun Aug 08 23:01:19 2010] [error] [client 127.0.0.1] File does not exist:
> [Sun Aug 08 23:03:18 2010] [error] [client 127.0.0.1] File does not exist:
> C:/mapbender/http/http
> [Sun Aug 08 23:03:55 2010] [error] [client 127.0.0.1] File does not exist:
> C:/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/.ui.tabs.js,
> referer: http://localhost/mapbender/frames/login.php
> [Sun Aug 08 23:04:12 2010] [error] [client 127.0.0.1] File does not exist:
> [Sun Aug 08 23:04:23 2010] [notice] Parent: child process exited with status
> 255 -- Restarting.
> [Sun Aug 08 23:04:24 2010] [notice] Apache/2.2.16 (Win32) PHP/5.3.3
> configured -- resuming normal operations
> [Sun Aug 08 23:04:24 2010] [notice] Server built: Jul 30 2010 16:15:37
> [Sun Aug 08 23:04:24 2010] [notice] Parent: Created child process 848
> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Child process is running
> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Acquired the start mutex.
> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Starting 64 worker threads.
> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Starting thread to listen on
> port 80.
> [Sun Aug 08 23:10:55 2010] [error] [client 127.0.0.1] File does not exist:
> [Sun Aug 08 23:11:06 2010] [notice] Parent: child process exited with status
> 255 -- Restarting.
> [Sun Aug 08 23:11:07 2010] [notice] Apache/2.2.16 (Win32) PHP/5.3.3
> [Sun Aug 08 23:11:07 2010] [notice] Server built: Jul 30 2010 16:15:37
> [Sun Aug 08 23:11:07 2010] [notice] Parent: Created child process 1672
> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Child process is running
> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Acquired the start mutex.
> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Starting 64 worker threads.
> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Starting thread to listen on
> port 80.
> Finally, the versions I downloaded are the following:
> Windows 7 / Apache 2.2.16 / PHP 5.3.3 / Poedit / Postgresql 8.4.4 / Postgis
> 1.5 / Geoserver 2.0.2 / Mapbender 2.6.2
> Thanks again!
> Sandra
FOSS4G 2010
06.-09. September 2010 in Barcelona
http://2010.foss4g.org
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
