[Mapbender-users] Load WMS: Problem with special characters
Astrid Emde astrid.emde at wheregroup.com
Fri Aug 13 08:28:50 EDT 2010
Hello Clemens,
There should not be a problem, when you Mapbender uses UTF-8 and your
Database too. It is also important that the WMS is defined with encoding
UTF-8 (please check this first).
Maybe you can send an example of these special characters so we can have a
closer look at the problem.
Which Mapbender version do you use?
Best regards
Astrid
On Wed, August 11, 2010 1:53 pm, beyer at multimediaplan.at wrote:
> Hi List,
> I encountered a problem with the Load WMS option a few days ago. The WMS
> was not loaded into my MB, and at least I could figure out that this
> happened because layer names are written with some special characters in
> the incoming return to the GetCapabilities request. (It's a Czech WMS -
> they have kind a lot of special characters there...)
> I asked the WMS provider if there were a possibility to put a service
> online without special characters, but unfortunately the answer was: "No,
> we do not have working time left for replacing these characters."
> I also saved the GetCapabilites doc on my system, replaced the special
> characters manually, and used the URL of the xml file instead of the real
> GetCapabilites URL to load the WMS. It loads into MB then, but cannot be
> displayed in the map (obviously because the layers themselvers contain
> characters, not only the layer descriptions).
> I would appreciate any help to solve this problem.
> Regards,
> Clemens
> Dipl.-Ing. Clemens Beyer
> CEIT ALANOVA gemeinnützige GmbH
> Concorde Business Park 2/F
> 2320 Schwechat
> Tel: ++43 664 885 19 555
> Fax: ++43 1 90360 - 1299
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
FOSS4G 2010
6.-9. September 2010 in Barcelona
http://2010.foss4g.org/
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Astrid Emde
FOSS4G 2010
 Astrid Emde
 Siemensstraße 8
 53121 Bonn
 Germany
 www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_users mailing list
