[Mapbender-users] 2.7
Arnulf Christl arnulf.christl at metaspatial.net
Wed Dec 22 04:04:22 EST 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hernan Olivera wrote:
> Hi again
> Is there any guide to use Openlayers apps in 2.7?
> thanks
Hi Hernan,
currently there are only the demo apps. But we are in the final works
for 2.7rc release today which will contain a default OL application. We
will then start to add some documentation on how to use the application.
Best regards,
Arnulf
> 2010/12/21 Hernan Olivera <lholivera at gmail.com>:
>> Hi Chris
>> You're right. I've done a first install mistaking pg password, and
>> reinstalling do not update that (erasing db previolusly). I have to
>> delete the folder and reinstall again. Now working.
>> Thanks
>> 2010/12/21 Christoph Baudson <christoph at baudson.de>:
> Hi Hernan,
> On 12/21/2010 10:30 PM, Hernan Olivera wrote:
>>>>> News:
>>>>> I've installed 2.7 on osgeo4, using different path and different database name.
>>>>> And pointed another apache virtual directory.
>>>>> But now I can't login with any user/pass.
>>>>> 2.6 is still working
>>>>> What is the procedure to work with 2.7?
> Please check if the database is installed correctly.
> You can do this by copying the file
> tools/mapbender_setup.php
> to
> http/php/mapbender_setup.php
> and calling the script via
> http://localhost/mapbender/php/mapbender_setup.php
> (or whatever the path is)
> Thanks
> Christoph
>>>>> thanks
>>>>>> Hi all
>>>>>> I'm stucked trying to make it work on centos. Someone have installed
>>>>>> mb 2.7 on centos successfully?
>>>>>> Now I'm changing my strategy, I'll try to install 2.7 on my 0sgeo4
>>>>>> installation. I hope it must work with all dependences.
>>>>>> I've seen the demo server with two versions working (2.6.2 y 2.7)
>>>>>> Do you think it will work if I use the installation script with
>>>>>> different path and different database name?
>>>>>> Or it is better to update 2.6.2, or delete it and install 2.7 from scratch?
>>>>>> I need to be working on 2.7
>>>>>> thanks
>>>>>> Hernan Olivera
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Hernan Olivera
Nothing makes sense, except we make it.
http://www.metaspatial.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAk0RvxYACgkQXmFKW+BJ1b3dQACfTr4Uu9ELtSdHMFXhxOOUxeYc
6Y4AoIMFFauiiWWUZPSXUkboW/vnQit1
=PxBn
-----END PGP SIGNATURE-----
More information about the Mapbender_users mailing list
