[Mapbender-users] 2.7
Armin Retterath armin.retterath at lvermgeo.rlp.de
Wed Dec 22 04:10:04 EST 2010
hello together,
another simple generation of an ol client can be done by using the mapbender
wmc docs:
http://www.mapbender.org/Mod_wmc2ol.php
regards
armin
Am Mittwoch 22 Dezember 2010, um 10:04:22 schrieb Arnulf Christl:
> Hernan Olivera wrote:
> > Hi again
> > Is there any guide to use Openlayers apps in 2.7?
> > thanks
> Hi Hernan,
> currently there are only the demo apps. But we are in the final works
> for 2.7rc release today which will contain a default OL application. We
> will then start to add some documentation on how to use the application.
> Best regards,
> Arnulf
> > 2010/12/21 Hernan Olivera <lholivera at gmail.com>:
> >> Hi Chris
> >> You're right. I've done a first install mistaking pg password, and
> >> reinstalling do not update that (erasing db previolusly). I have to
> >> delete the folder and reinstall again. Now working.
> >> Thanks
> >> 2010/12/21 Christoph Baudson <christoph at baudson.de>:
> > Hi Hernan,
> > On 12/21/2010 10:30 PM, Hernan Olivera wrote:
> >>>>> News:
> >>>>> I've installed 2.7 on osgeo4, using different path and different
> >>>>> database name. And pointed another apache virtual directory.
> >>>>> But now I can't login with any user/pass.
> >>>>> 2.6 is still working
> >>>>> What is the procedure to work with 2.7?
> > Please check if the database is installed correctly.
> > You can do this by copying the file
> > tools/mapbender_setup.php
> > to
> > http/php/mapbender_setup.php
> > and calling the script via
> > http://localhost/mapbender/php/mapbender_setup.php
> > (or whatever the path is)
> > Thanks
> > Christoph
> >>>>> thanks
> >>>>>> Hi all
> >>>>>> I'm stucked trying to make it work on centos. Someone have installed
> >>>>>> mb 2.7 on centos successfully?
> >>>>>> Now I'm changing my strategy, I'll try to install 2.7 on my 0sgeo4
> >>>>>> installation. I hope it must work with all dependences.
> >>>>>> I've seen the demo server with two versions working (2.6.2 y 2.7)
> >>>>>> Do you think it will work if I use the installation script with
> >>>>>> different path and different database name?
> >>>>>> Or it is better to update 2.6.2, or delete it and install 2.7 from
> >>>>>> scratch? I need to be working on 2.7
> >>>>>> thanks
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
