[Mapbender-users] 2.7
Hernan Olivera lholivera at gmail.com
Wed Dec 22 07:59:28 EST 2010
2010/12/22 Arnulf Christl <arnulf.christl at metaspatial.net>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hernan Olivera wrote:
>> Hi again
>> Is there any guide to use Openlayers apps in 2.7?
>> thanks
> Hi Hernan,
> currently there are only the demo apps. But we are in the final works
> for 2.7rc release today which will contain a default OL application. We
> will then start to add some documentation on how to use the application.
That's ok.
I have imported the app: psql -f template_openlayers.sql mapbender27
Ican see it, but the openlayers map an menu are blank.
suggestions?
> Best regards,
> Arnulf
>> 2010/12/21 Hernan Olivera <lholivera at gmail.com>:
>>> Hi Chris
>>> You're right. I've done a first install mistaking pg password, and
>>> reinstalling do not update that (erasing db previolusly). I have to
>>> delete the folder and reinstall again. Now working.
>>> Thanks
>>> 2010/12/21 Christoph Baudson <christoph at baudson.de>:
>> Hi Hernan,
>> On 12/21/2010 10:30 PM, Hernan Olivera wrote:
>>>>>> News:
>>>>>> I've installed 2.7 on osgeo4, using different path and different database name.
>>>>>> And pointed another apache virtual directory.
>>>>>> But now I can't login with any user/pass.
>>>>>> 2.6 is still working
>>>>>> What is the procedure to work with 2.7?
>> Please check if the database is installed correctly.
>> You can do this by copying the file
>> tools/mapbender_setup.php
>> to
>> http/php/mapbender_setup.php
>> and calling the script via
>> http://localhost/mapbender/php/mapbender_setup.php
>> (or whatever the path is)
>> Thanks
>> Christoph
>>>>>> thanks
>>>>>>> Hi all
>>>>>>> I'm stucked trying to make it work on centos. Someone have installed
>>>>>>> mb 2.7 on centos successfully?
>>>>>>> Now I'm changing my strategy, I'll try to install 2.7 on my 0sgeo4
>>>>>>> installation. I hope it must work with all dependences.
>>>>>>> I've seen the demo server with two versions working (2.6.2 y 2.7)
>>>>>>> Do you think it will work if I use the installation script with
>>>>>>> different path and different database name?
>>>>>>> Or it is better to update 2.6.2, or delete it and install 2.7 from scratch?
>>>>>>> I need to be working on 2.7
>>>>>>> thanks
>>>>>>> Hernan Olivera
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Hernan Olivera
> Nothing makes sense, except we make it.
> http://www.metaspatial.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAk0RvxYACgkQXmFKW+BJ1b3dQACfTr4Uu9ELtSdHMFXhxOOUxeYc
> 6Y4AoIMFFauiiWWUZPSXUkboW/vnQit1
> =PxBn
> -----END PGP SIGNATURE-----
Hernan Olivera
More information about the Mapbender_users mailing list
