****SPAM Mail****[Mapbender-users] Fehler beim Hochladen der Capabilities
Marc Jansen jansen at terrestris.de
Thu Feb 4 04:54:41 EST 2010
Hallo Martina,
Sieht so aus als ob
http://foehr.xxx.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
<http://foehr.xxx.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1>
kein GetCap ausgibt.
Kann das sein?
Ciao,
Marc
martina ikert wrote:
> *Ausgabe bei Angabe von*
> TEMPLATE
> "http://foehr.xxx.de:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen
> <http://foehr.xxx.de:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen>":
> foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # wget -O /tmp/caps.xml
> [1] 32326
> [2] 32327
> [3] 32328
> --17:02:13--
>             => `/tmp/caps.xml'
> Resolving foehr.xxx.de...
> foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # 127.0.0.2
> Connecting to foehr.xxx.de|127.0.0.2|:8080... connected.
> HTTP request sent, awaiting response... 302 Found
> Location:
> [following]
> --17:02:13--
>             => `/tmp/caps.xml'
> Reusing existing connection to foehr.xxx.de:8080.
> Location:
> http://foehr.xxx.de:8080/mapbender1/http/frames/login.php [following]
> --17:02:13--
>             => `/tmp/caps.xml'
> HTTP request sent, awaiting response... 200 OK
> Length: 1,161 (1.1K) [text/html]
> 100%[========================================================================================>]
> 1,161         --.--K/s
> 17:02:13 (70.13 MB/s) - `/tmp/caps.xml' saved [1161/1161]
> [1]   Done                    wget -O /tmp/caps.xml
> [2]-  Done                    REQUEST=GetCapabilities
> [3]+  Done                    SERVICE=WMS
> Inhalt von caps.xml:
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
> <html>
> <head>
> Licensing: See the GNU General Public License for more details.
> http://www.gnu.org/copyleft/gpl.html
> or:
> mapbender/licence/
> <meta http-equiv="cache-control" content="no-cache">
> <meta http-equiv="pragma" content="no-cache">
> <meta http-equiv="expires" content="0">
> <meta http-equiv="Content-Type" content="text/html;
> "><title>Login</title>
> <link rel="stylesheet" type="text/css" href="../css/login.css"><script
> type='text/javascript'><!--
> function
> setFocus(){if(document.loginForm){document.loginForm.name.focus();}}// -->
> </script></head><body onload='setFocus()'><form name='loginForm' action
> ='' method='POST'><table><tr><td>Name: </td><td><input type=
> 'text' name='name' class='login_text'
> value=''></td></tr><tr><td>Password: </td><td><input type='password'
> name='password' class='lo
> gin_text'></td></tr><tr><td></td><td><input type='submit'
> class='myButton' value='login' title='anmelden'>  <a href='../ph
> p/mod_forgottenPassword.php' title='Passwort vergessen?'
> target='_blank'>Forgot your password?</a></td></tr></table></form></body>
> </html>
> TEMPLATE
> "/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&gui_id=Expeditionen":
> foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # more /tmp/caps.xml
> Content-type: text/html
> <HTML>
> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
> <!-- MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS
> =FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORT
> S=GEOS SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE -->
> <BODY BGCOLOR="#FFFFFF">
> msReturnPage(): Web application error. Malformed template name
> (/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&
> amp;gui_id=Expeditionen).
> </BODY></HTML>
> [1] 32231
> [2] 32232
> [3] 32233
> --16:48:35--
>             => `/tmp/caps.xml'
> Resolving foehr.xxx.de... 127.0.0.2
> Length: unspecified [text/html]
>                         ] 569           --.--K/s
> 16:48:35 (33.86 MB/s) - `/tmp/caps.xml' saved [569]
> <HTML>
> INPUT=SHAPEFILE -->
> mapserv(): Web application error. Traditional BROWSE mode requires a
> TEMPLATE in the WEB section, but none was provided.
> </BODY></HTML>
> Deine Erläuterungen zum TEMPLATE habe ich nicht verstanden.
> Wie muss ich in der map-Datei im TEMPLATE die Anbindung zur Mapbender
> GUI machen. Ich habe ja keine html-Seite als template.
> Ich weiß leider nicht mehr, wo ich diese Anweisung im TEMPLATE gelesen
> habe, aber lokal hat es immer geklappt.
> Viele Grüße
> Martina
> > Date: Mon, 1 Feb 2010 11:46:12 +0100
> > Subject: Re: ****SPAM Mail****[Mapbender-users] Fehler beim
> > From: mschulz at webgis.de
> > To: mapbender_users at lists.osgeo.org
> > Hallo Martina,
> > könntest Du mal den Inhalt des Ergebnisses des letzten wget Aufrufes
> > posten? Mit dem Flag wget -O landet ja das Ergebnis in einer Datei (am
> > besten irgendwo im /tmp), dieses Ergebnis kann der Mapbender noch
> > nicht korrekt parsen, daher kommt noch der Fehler. Es ist also nicht
> > nur $1 leer, sondern alle Variablen - aber der erste verletzte
> > Constraint in der DB löst halt den Fehler aus. Von demher ist die
> > Fehlermeldung etwas irreführend. Wichtig wäre also weiterhin die
> > Antwort eures GetCapabilities-Aufrufes per wget zu checken (und evtl.
> > hier zu posten).
> > Eine Sache zum Mapserver loggen: Im "normalen" Mapserver-Log (das per
> > LOG angesprochen wird) erhältst Du zwar letztendlich eine
> > Fehlermeldung aber kein Debug-output. "Richtiges" debugging am besten
> > per CONFIG "MS_ERRORFILE" "/tmp/mapserver.log" im MAP-Objekt und DEBUG
> > on bei den Layern aktivieren.
> > Zum TEMPLATE: Bist Du Dir sicher, dass Du im TEMPLATE wieder ein
> > Mapbender-GUI aufrufen willst? Als erstes würde ich mal einfach einen
> > dummy-template Eintrag nehmen (TEMPLATE "dummy") , das dazu führt,
> > dass die Ebene abfragbar ist. Dann bei den GUI-WMS-Einstellungen als
> > info/format "text/plain" auswählen.
> > Viele Grüße, Michael
> > Am 1. Februar 2010 10:32 schrieb martina ikert
> <martinaikert at hotmail.com>:
> > > Hallo Michael,
> > > am Freitag abend konnten wir wieder ein bisschen ausprobieren.
> > > Wir haben die Funktion wget benutzt und bekamen einige
> Fehlermeldungen, die
> > > wir nach und nach bereinigen konnten.
> > > Zuletzt hatten wir folgende Fehlermeldung:
> > > Ältere behobener Inhalt: von "rlp.log":
> > > Fri Jan 29 16:51:26 2010,14722,127.0.0.2,Vessels,0,-180.004167
> > > -164.995833 179.995833 195.004167,-1.000000 -1.000000,,msReturnPage
> (/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&gui_id=Exp
> > > editionen). <br>
> > > Daraufhin haben wir in der map-Datei folgendes ausprobiert, obwohl
> > > unlogisch, nach untenstehenden Definitionen:
> > >    TEMPLATE
> "http://ServerURL:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen"
> > > ####    TEMPLATE
> > > Aktuellster Inhalt der rlp.log:
> > > Fri Jan 29 17:12:24 2010,15153,127.0.0.2,Vessels,0,-180.004167
> > > -164.995833 179.995833 195.004167,-1.000000 -1.000000,,normal
> execution
> > > Es gibt also in der log-Datei keine Fehlermeldungen mehr, aber die
> > > Fehlermeldung beim Hochladen der Capabilities besteht.
> > > Dazu mal die Eintragung in der pgsql-log:
> > > 2010-01-29 17:14:55 CET mapbender postgres FEHLER:  NULL-Wert in
> Spalte
> > > »wms_title« verletzt Not-Null-Constraint
> > > 2010-01-29 17:14:55 CET mapbender postgres ANWEISUNG:  UPDATE wms SET
> > > wms_title  = $1 ,wms_abstract  = $2 ,fees = $3, accessconstr
> > > aints = $4, contactperson = $5,
> > > ($1 <-- ist anscheind wirklich leer, woher kommt $1 ??
> > > Was bei unserem WebGIS an sich noch nicht funktioniert ist die
> > > featureInfo-Funktion.
> > > Bei einem Klick auf eine Stationskoordinate öffnen sich immer 2
> > > leere Fenster, nicht aber das HTML-Template. In einer Tabelle
> sollten die
> > > Daten zu der Station zu lesen sein.
> > > Wie kommen wir da weiter?
> > > Viele Grüße
> > > Martina
> > > Auszug aus meinen Recherchen:
> > > They guide the presentation of results, either a query or a map,
> to the
> > > user. Templates are almost always HTML files although they can
> also be a URL
> > > (e.g.. http://www.somewhere.com/[ATTRIBUTE]/info.html). URL
> templates can
> > > only be used with simple QUERY or ITEMQUERY results so many
> substitutions
> > > defined below are not available for them. Simple pan/zoom
> interfaces use a
> > > single template file while complicated queries often require many
> templates.
> > > Templates often use JavaScript to enhance the basic interface.
> > > msReturnPage(): Web application error. Malformed template name¶
> > > This error may occur when you are attempting to use a URL template
> for a
> > > query. The issue is that URL templates are only allowed for query
> modes that
> > > return only one result (e.g. query or itemquery)
> > > You can only use a URL template for a query in mode=query or
> mode=itemquery.
> > > If you try it with mode=nquery or mode=itemnquery, you will get
> the error:
> > > Content-type: text/html msReturnPage(): Web application error.
> Malformed
> > > template name
> > >> Date: Thu, 21 Jan 2010 09:17:58 +0100
> Hochladen der
> > >> Capabilities
> > >> Hallo Martina,
> > >> klar, das ist die Fehlermeldung im Mapbender-Log. Wenn der Mapbender
> > >> meldet das die WMS-Version die Not-Null Bedingung verletzt ("Error:
> > >> FEHLER: NULL-Wert in Spalte »wms_version« verletzt
> > >> Not-Null-Constraint"), heißt das soviel wie, das in der Antwort auf
> > >> die GetCapabilities-Anfrage vermutlich gar keine WMS-Getcapabilities
> > >> drinnen sind. Daher hatte Armin schon vorgeschlagen:
> > >> "in der class_connector.php function load einfach mal ein $e=new
> > >> mb_exception('class_connector.php: loaded external data: ',$data);
> > >> eintragen
> > >> (vor der return.. zeile)"
> > >> also ein zusätzlichen Log-Eintrag zu erstellen. Der bisherige Auszug
> > >> aus dem Logfile zeigt die Standard-Fehlermeldung vom Mapbender, der
> > >> zusätzliche Eintrag würde Dir den Inhalt der GetCapabilities-Antwort
> > >> im Log anzeigen. Als quasi äquivalente Möglichkeit kannst Du den
> > >> GetCapabilities Aufruf auch von dem Mapbender-Server (aber nicht aus
> > >> der Mapbender-Oberfläche) per wget absetzen um mal zu sehen, was da
> > >> eigentlich zurückkommt.
> > >> Am 21. Januar 2010 08:38 schrieb martina ikert
> > >> > Hallo Michael,
> > >> > ich habe dir noch einmal die Fehlermeldung kopiert. Das war der
> Tipp von
> > >> > Armin.
> > >> > 2010.01.15, 17:59:48,mb_validateSession.php: GUI: admin2_de,
> checking
> > >> > file /mapbender1/http/php/mod_updateWMS.php...session valid.
> > >> > 2010.01.15, 17:59:48,mb_validatePermission.php: checking file
> > >> > /mapbender1/http/php/mod_updateWMS.php...permission valid.
> > >> > 2010.01.15, 17:59:48,connector: unable to load:
> http://our-server.domaine.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> > >> > 2010.01.15, 17:59:48,Error while executing prepared statement in
> /tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/php/mod_updateWMS.php:
> > >> > Sql: UPDATE wms SET wms_version = $1 ,wms_getcapabilities  = $2
> > >> > ,wms_getmap  = $3 ,wms_getfeatureinfo  = $4 ,wms_getlegendurl  = $5
> > >> > ,wms_getcapabilities_doc = $6 ,wms_upload_url = $7,  wms_owner
> = $8,
> > >> > wms_timestamp = $9  WHERE wms_id = $10, Error: FEHLER:
> NULL-Wert in
> > >> > Spalte »wms_version« verletzt Not-Null-Constraint
> > >> > Viele Grüße
> > >> > Martina
> > >> >> Date: Wed, 20 Jan 2010 16:25:38 +0100
> Hochladen
> > >> >> der
> > >> >> Capabilities
> > >> >> Hallo Martina,
> > >> >> kannst Du dich auf dem Server wo der Mapbender läuft einloggen und
> > >> >> dort auf der Kommandozeile mal folgenden Befehl absetzen:
> "http://our-server.domaine.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1"
> > >> >> Dann sollte in der Datei caps.xml im /tmp Verzeichnis die
> Antwort auf
> > >> >> die GetCapabilities-Anfrage stehen, was recht wahrscheinlich
> > >> >> irgendeine Fehlermeldung sein wird. Das ist ungefähr das
> gleiche, wie
> > >> >> es Armin Retterath schon vorgeschlagen hat, aber ich hatte nichts
> > >> >> gefunden im thread, ob Du das mal probiert hast.
> > >> >> Am 20. Januar 2010 16:03 schrieb martina ikert
> > >> >> > Hallo Karim,
> > >> >> > in php.ini ist
> > >> >> > allow_url_fopen = On
> > >> >> > Wir haben heute wieder viel rumprobiert, aber es ist keine
> Lösung in
> > >> >> > Sicht.
> > >> >> > Beim Upload der Capabilities gibt es immer noch die gleiche
> > >> >> > Fehlermeldung.
> > >> >> > So langsam ist es wirklich frustrierend.
> > >> >> > Hat denn sonst niemand lokal gearbeitet und hat dann die
> Dateien auf
> > >> >> > einen
> > >> >> > Server installiert?
> > >> >> > Viele Grüße
> > >> >> > Martina
> > >> >> >> Date: Mon, 18 Jan 2010 11:15:20 +0100
> > >> >> >> From: karim at malhas.de
> > >> >> >> Hochladen
> > >> >> >> der
> > >> >> >> Capabilities
> > >> >> >> Hallo Martina,
> > >> >> >> > Hat jemand noch einen guten Tipp?
> > >> >> >> Schau mal nach ob in deiner php.ini
> > >> >> >> gesetzt ist.
> > >> >> >> Gruß,
> > >> >> >> Karim
> > >> >> >> _______________________________________________
> > >> >> >> Mapbender_users mailing list
> > >> >> >> Mapbender_users at lists.osgeo.org
> > >> >> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > >> >> > Windows Live: Keep your friends up to date with what you do
> online.
> > >> >> Aufwind durch Wissen!
> > >> >> Qualifizierte Open Source Schulungen bei der
> > >> >> http://www.foss-akademie.de/
> > >> >> Michael Schulz
> > >> >> in medias res
> > >> >> Gesellschaft für Informationstechnologie mbH
> > >> >> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
> > >> >> Schwimmbadstraße 2
> > >> >> D-79100 Freiburg i. Br.
> > >> >> Tel: +49 (0)761 705798-102
> > >> >> Tel: +49 (0)761 705798-0
> > >> >> Fax: +49 (0)761 705798-09
> > >> >> http://www.webgis.de / http://www.zopecms.de
> > >> >> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> > >> >> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
> > >> > Windows Live Hotmail: Your friends can get your Facebook
> updates, right
> > >> > from
> > >> > Hotmail®.
> > >> Michael Schulz
> > >> in medias res
> > >> Schwimmbadstraße 2
> > > Hotmail: Trusted email with powerful SPAM protection. Sign up now.
> > Michael Schulz
> > in medias res
> > Schwimmbadstraße 2
> Hotmail: Powerful Free email with security by Microsoft. Get it now.
> <https://signup.live.com/signup.aspx?id=60969>
  Dipl.-Geogr. Marc Jansen
  - Anwendungsentwickler -
  terrestris GmbH & Co. KG
  Irmintrudisstraße 17
  53111 Bonn
  Tel:    ++49 (0)228 / 96 28 99 -53
  Fax:    ++49 (0)228 / 96 28 99 -57
  Email:  jansen at terrestris.de
  Web:    http://www.terrestris.de
  Amtsgericht Bonn, HRA 6835
  Komplementärin:  terrestris Verwaltungsgesellschaft mbH
  vertreten durch: Hinrich Paulsen, Till Adams
More information about the Mapbender_users mailing list
