[Mapbender-users] GazetteerWFS nodes problem
Edison Bravo ebravo at mail.igm.gov.ec
Mon Feb 22 10:39:56 EST 2010
Hello Astrid
Thank you very much for your reply.
As a contribution, I have considered increasing the parameter:
"memory_limit" in the PHP configuration (php.ini) that helps solve this
problem in part.
Best regards
Edison
El 08/02/2010 2:50, Astrid Emde escribió:
> Hello Edison,
> On Fri, February 5, 2010 2:47 pm, Edison Fernando Bravo Chancay wrote:
>> Hello list
>> What is the maximum number of nodes that a gazetteer can do a search?
>> I have more than 20,000 nodes in one polygon and no searching
> 20.000 nodes if far too much, as the resultGeometry is transfered into
> the Client into a GeoJSON.
>> and how can I change this parameter?
> There is no Mapbender parameter which you can change.
> But you could change the WFS access on your data:
> If you have your data in a PostgreSQL database you can easily change
> the query and do a search on the boundingbox of your polygon or on a
> simplyfied polygon with less nodes.
> CREATE VIEW query_mytable AS
> SELECT gid, name, st_envelope(the_geom) as the geom FROM mytable;
> SELECT gid, name, st_simplify(the_geom,100) as the geom FROM mytable;
> I hope this information will help.
> Best regards
> Astrid
> [1] http://postgis.org/documentation/manual-1.5/ST_Envelope.html
> [2] http://postgis.org/documentation/manual-1.5/ST_Simplify.html
>> Edison
>> Este mensaje ha sido analizado por MailScanner
>> en busca de virus y otros contenidos peligrosos, y se considera que está
>> limpio.
>> INSTITUTO GEOGRAFICO MILITAR
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
y se considera que está limpio.
More information about the Mapbender_users mailing list
