[Mapbender-users] gazetteerWFS no search result
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Tue Feb 23 05:50:01 EST 2010
Hi Tilo,
maybe this issue is already solved in the latest version of the branch 2.6.
Maybe compare the classes in the folder http/classes with your copy of
2.6, and merge the changes in the WFS classes in your copy.
Christoph
Tilo Wütherich schrieb:
> Hi Mapbender-Devs,
>>> I have perhaps a coding problem with gazetteerWFS. If I
>>> search for words
>>> with Umlaute, I get no results. My setup is:
>> I found the the mistake: changing to define("CHARSET",
>> "ISO-8859-1") helped.
>> I'm just wondering why, because all of my datasources are UTF-8...
> I found out, that this is not a good idea: after changing this, I cannot
> update WMS or WFS anymore. So I have to change back and forth - this seems
> to be a bug.
> Shall I open a trac-ticket?
> Greetings,
> Tilo
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
