[Mapbender-users] gazetteerWFS no search result
Tilo Wütherich tilo.wuetherich at la-bw.de
Wed Feb 24 05:44:53 EST 2010
Hi Christoph,
after a new test, I see that it's only a problem with WMS-update, WFS-import
/ update works with both charsets.
Greetings,
Tilo
> -----Original Message-----
> From: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of
> Christoph Baudson (Wheregroup)
> Sent: Tuesday, February 23, 2010 11:50 AM
> To: Mapbender User List
> Subject: Re: [Mapbender-users] gazetteerWFS no search result
> Hi Tilo,
> maybe this issue is already solved in the latest version of
> the branch 2.6.
> Maybe compare the classes in the folder http/classes with
> your copy of
> 2.6, and merge the changes in the WFS classes in your copy.
> Christoph
> Tilo Wütherich schrieb:
> > Hi Mapbender-Devs,
> >>> I have perhaps a coding problem with gazetteerWFS. If I
> >>> search for words
> >>> with Umlaute, I get no results. My setup is:
> >> I found the the mistake: changing to define("CHARSET",
> >> "ISO-8859-1") helped.
> >> I'm just wondering why, because all of my datasources are UTF-8...
> > I found out, that this is not a good idea: after changing
> this, I cannot
> > update WMS or WFS anymore. So I have to change back and
> forth - this seems
> > to be a bug.
> > Shall I open a trac-ticket?
> > Greetings,
> > Tilo
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> FOSSGIS Konferenz 2010
> 2. - 5. März 2010 in Osnabrück
> http://www.fossgis.de/konferenz
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> christoph.baudson at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
