[Mapbender-users] WFS Search Result Problem
Michael Schulz mschulz at webgis.de
Fri Feb 26 08:24:51 EST 2010
> Therefore I just copy the extend of my system under the wgs extend. I
> found the solution in some forum.
hmm, this sounds a little bit strange. You are using Geoserver as
WMS-Server also, right? The problem here with Geoserver is, that it
exhibits the layers extent only at the sublayer level, i.e. you have a
layer that uses epsg;31259 and you have set a bbox for that layer,
you'll find the coresponding <BoundindBox> tag at this layer, but not
at the main layer, therefore mapbender will not be able to select your
sublayers epsg as a selectable epsg-system in the gui_wms_settings
dialog.
To achieve that you can either manipulate your capabilities document
by hand, add the sublayer BoundingBox tag also to the main layer and
upload your wms from a static file rather than from a getcapabilties
call. Or you can copy the entry of your sublayer in table layer_epsg
to the main layer by assigning it the correct layer_id. I'd recommend
the first option, because fiddling with the DB by hand is always ...
dangerous.
Cheers, Michael
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
