[Mapbender-users] WFS Search Result Problem [solved]
Michael Schulz mschulz at webgis.de
Fri Feb 26 08:26:12 EST 2010
ok, great.
Michael
2010/2/26 Andreas Voit <a_voit at gmx.at>:
> hi,
> I tried again to change to wfs 1.0.0 and found the update option under
> "Wfs konfiguration GUI zuweisen". After changing the request parameter
> to version=1.0.0, and update my wfs, the search result zooms to the
> correct location/coordinates.
> Former I deleted the whole wfs and inserted it again. Perhaps it was
> inserted as wfs 1.1.0 although the request version was on wfs 1.0.0 .
> thanks for your help, you saved my weekend ;)
> andreas voit
> Am 26.02.2010 13:35, schrieb Michael Schulz:
>> Hi,
>> next try: change the type to "MultiPolygonPropertyType".
>> Cheers, Michael
>> P.S.: I was struggling with the same stuff recently...
>>> hi,
>>> thanks for your fast answer, i was very astonished ;)
>>> to my problem.
>>> - i changed the geoserver wfs settings to normal.
>>> - i changed to wfs 1.0
>>> - in the mapbender db was MultiSurfacePropertyType and I changed it to
>>> MULTIPOLYGON
>>> but the error still occurs. the epsq should be the same.
>>> and I also get in the error logfile "WFS gazetteer: geometry type unknown".
>>> thanks
>>> Am 26.02.2010 11:12, schrieb Michael Schulz:
>>>> Hi,
>>>> welcome to Mapbender!
>>>> WFS configuration is still a bit complicated, although Mapbender
>>>> really does a good job with that. Some things to check:
>>>> - have you uploaded your WFS as version 1.0 or 1.1? With Mapbender 2.6
>>>> I'd stick to version 1.0
>>>> - in Geoserver set your WFS-GML-SRS style to "normal" (under Services
>>>> - WFS, scroll down to the bottom)
>>>> - check the returned geometryType of your featuretype. I think
>>>> Mapbender will only handle the "frequently" used ones, like POLYGON,
>>>> MULTIPOLYGON, LINESTRING, etc... I am not sure why (I think it has to
>>>> do with what kind of datastore you use), but Geoserver sometimes
>>>> exposes your featureType as MultiSurfacePropertyType or the like...
>>>> (if that has happened, you may need to change the geometryType by hand
>>>> in the mapbender DB)
>>>> - make sure you connect the wms layer to the right wfs conf (but i
>>>> think if you already get results, that's already done)
>>>> - epsg-srs must match between WMS-GUI-setting and WFS featuretype
>>>> - your coordinate example seems to me as if you bitten by the
>>>> coordinate axis order confusion with wfs 1.1: see the first point.
>>>> These are some points to check. Mapbender 2.6 should work well with
>>>> Geoserver 2.0.1, at least I have it working with epsg:31467.
>>>> Have fun, Michael
>>>>> hello,
>>>>> I'm new to mapbender. I use mapbender 2.6, postgresql 8.4, geoserver
>>>>> 2.01, xampp 1.7.3, windows xp sp3, firefox 3.6 .
>>>>> To my problem:
>>>>> I use geoserver as my datacenter. I use the wms to show my maps. I
>>>>> started to use wfs for searching. Therefor I use the gazetteerwfs
>>>>> module. Over the WFS come multipolygons from my postgresql db.
>>>>> My Problem occurs when I use the searching. I use a dropdown menu to
>>>>> select a value. the selection finds the correct feature and when I click
>>>>> at the result it starts zooming. But it ends up with a white map. When I
>>>>> mouse over the result, the polygon gets highlighted.
>>>>> I found out, that the zoomed feature has incorrect coordinates.
>>>>> I mean the correct coordinates are for example 734078.4, 214992.6 and
>>>>> the zoomed feature has 214992.6, 734078.4.
>>>>> I use EPSG 31259.
>>>>> To find a solution I used firebug. I found the function setResult(event,
>>>>> index) under http/javascript/mod_wfs_gazetteer_client.php and chanced
>>>>> the extend calculation to
>>>>> parent.mb_calculateExtent(targetArray[0], bbox[0].y, bbox[0].x,
>>>>> bbox[1].y, bbox[1].x); .
>>>>> After that the wfs search result zoomed to the correct extend, but the
>>>>> highlighting doesn't show up. In my opinon the highlight feature
>>>>> coordinates are still uncorrect.
>>>>> I also should mention, I looked into the mapbender logfiles and found
>>>>> out, that when I press the wfs search button, it writes an error into
>>>>> the logfile: [TIMESTAMP] ERROR: WFS gazetteer: geometry type unknown.
>>>>> could that be the problem for the incorrect coordinates? I also don't
>>>>> understand the unknown geometry type error.
>>>>> does anybody know how to fix the coordinate problem?
>>>>> thanks
>>>>> Andreas Voit
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Andreas Voit
>>> http://andreasvoit.heim.at/
>>> Windows kam, sah und versagte
> Andreas Voit
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
