[Mapbender-users] WFS-Search: Select for Boolean/Integer
Verena Diewald verena.diewald at wheregroup.com
Wed Aug 3 03:33:20 EDT 2011
Hi Frank,
tried that configuration in one of my wfs configurations in MB 2.7.1 and
it worked fine.
Is your gazetteerWFS module integrated in the tab element vars? And did
you assign your wfs conf to the gui in which you want to use it?
Is the search-Tab working in the right way with other wfs confs?
Best regards,
Verena
Am 02.08.2011 17:56, schrieb "Jäger, Frank (KRZ)":
> Hi,
> I try to configure a WFS-Search in Mapbender 2.7.1.
> Data from a PostGIS-DB comes as WFS via mapbender 6.0.1.
> An integer-column in PostGIS has the Values 0 and -1 (and sometimes null) - meaning true/false.
> I like to let the user select one of the values, took the HTML-Template "Selectbox" and configured:
> <select id='baumtyp'>
> <option>...</option>
> <option value='0'>Nadelbaum</option>
> <option value='-1'>Laubbaum</option>
> </select>
> The result is:
> By clicking the Search-Button the Search-Tab becomes "invisible".
> Firebug:
> document.getElementById(el[i].element_name) is null
> Mit freundlichen Grüßen
> Frank Jäger
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
