Antw.: [Mapbender-users] Problem with SRS EPSG:4189
Valenty Gonzalez gvalenty at gmail.com
Tue Aug 16 18:25:35 EDT 2011
Arnulf,
I'm using MB version 2.6.2 on Debian Squeeze (Linux desarrollo
2.6.26-2-686). Sorry for not include this information before :-S
URL to Capabilities:
http://200.75.140.108:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetCapabilities
Regards,
Valenty
El 16/08/2011 05:21 p.m., Arnulf Christl escribió:
> Valenty,
> can you send the URL to the Capabilities document, or if it is local
> just the XML file. And what MB version are you running?
> Best regards,
> Arnulf
> Seven (aka Arnulf)
> http://arnulf.us
> ----- Reply message -----
> Von: "Valenty Gonzalez" <gvalenty at gmail.com>
> An: <mapbender_users at lists.osgeo.org>
> Betreff: [Mapbender-users] Problem with SRS EPSG:4189
> Datum: Di., Aug. 16, 2011 23:15
> Hi,
> I need to offer a Geoportal with SRS EPSG:4189
> The SRS EPSG: 4189 corresponds to the projection REGVEN,for the Republic
> of Venezuela.
> Problem is, that I build a WMS from Geoserver with that projection
> (4189) and when I go to Mapbender by linking the WMS to a GUI always
> reads as SRS EPSG: 4326
> This situation succes even if i don'tdeclare 4326 in the configuration
> of WMS.
> So, when i go to the GUI_settings, this option not give me an
> opportunity to select EPSG: 4189 and SRS for the portal service. Only
> offer 4326 (by default?)
> Any ideas?
> Thanks in advance,
> Valenty Gonzalez
> CREATIVA
> Venezuela
> Asociación gvSIG
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110816/507bdbf8/attachment.html
More information about the Mapbender_users mailing list
