[Mapbender-users] 2.7 rc1 problem
Thoralf Kauk tkauk at t-online.de
Wed Jan 19 10:39:46 EST 2011
Am 19.01.2011 14:13, schrieb Hernan Olivera:
> News:
> I've installed 2.6.2 in the same machine, withouth any problem.
> Now this is my scenario:
> 1) Solve 2.7 problems to work
> 2) Use 2.6.2, but need to know what to do to use Openlayers example.
> Someone can help?
Is the openlayer template app working?
Do you get the admin apps workink ?
Perhaps this is a similar problem as under Win 7 ( file_get_contents
with complete url [ala http://localhost/mapbender/....] doesn't work).
You can try to comment out the file_get_contents in
http\javascripts\initWmcObj.php
on line 413.
Thoralf
> By the way, I'm trying to make an Openlayers App with google maps
> included, inside mapbender.
> saludos
> 2011/1/19 Hernan Olivera <lholivera at gmail.com>:
>> Hi
>> I've solved the problem (selinux=disabled) for log files. Now setup is
>> all green :)
>> But mapbender does not load apps:  Mapbender 2.7 rc1...loading
>> application 'gui1'
>> Where to look now?
>> 2011/1/18 Hernan Olivera <lholivera at gmail.com>:
>>> 2011/1/18 Thomas Baschetti <info at thomas-baschetti.de>:
>>>> On 18.01.2011 20:21, Hernan Olivera wrote:
>>>>> Hi
>>>>> I'm working with 2.7 rc1 on CentOS, with the installing script and all
>>>>> dependencies ok.
>>>>> Now mapbender_setup.php looks good, except for the line error logging:
>>>>> Unable to open or generate
>>>>> /opt/mapbender_2.7/core/../log/mb_error_2011_01_18.log.
>>>>> This is the ls -l report on the log dir:
>>>>> drw-rw-rw-  2 apache apache  4096 ene 18 15:22 log
>>>> try changing the permissions so the directory is executable (means you
>>>> can change to that dir)
>>>> chmod +x log
>>> Hi Thomas
>>> I've tried +x and 777, with the same results.
>>> The user and group is apache, which is the apache user, like www-data in debian.
>>> I'll try isolating the php code, but I've seen a lor of strange things
>>> with CentOS.
>>> I've disabled error logging in mapbender, with the same results,
>>> waiting forever to load app.
>>> thanks
>>>> Thomas
>>>> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
>>>> Hakenstraße 8D
>>>> 49074 Osnabrück
>>>> Tel: 0541 25 91 90 | mobil 01577 189 25 91
>>>> E-Mail: info at thomas-baschetti.de
>>>> www.thomas-baschetti.de
>>>> Ust-IdNr.: DE264355072
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Hernan Olivera
>> Hernan Olivera
More information about the Mapbender_users mailing list
