AW: [Mapbender-users] 2.7 rc1 problem
Manns, Marc manns at str.de
Mon Jan 24 02:18:13 EST 2011
Hi Hernan,
there's a problem with an ui-element in
this application.
I fixed it in 2.7 branch and trunk.
see:
http://trac.osgeo.org/mapbender/changeset/7411
Just load this sql in your mapbender database
and it should be fixed.
regards marc
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Hernan Olivera
Gesendet: Freitag, 21. Januar 2011 16:43
An: Mapbender User List
Betreff: Re: [Mapbender-users] 2.7 rc1 problem
Hi
OpenLayers example does not function (loading...) in 2.7 rc1, but is ok in 2.7 alpha.
I've tested it on two different configurations.
Someone reporting the same?
2011/1/19 Hernan Olivera <lholivera at gmail.com>:
> Ok.
> I have downloaded again 2.7 rc1, reinstalled from scratch and all is
> working well.
> I can't explain this. Maybe a newer 2.7?
> Thanks. I've learned a lot :)
>>> Thanks. But I think these are not real errors. We should mark them
>>> as notices.
>> Ok, I've set ALL & NOTICE,
>>> Any chance you got sth in your PHP error log? You can enable it in
>>> php.ini, sth. like
>>> logErrors = On
>>> errorLog = <filename>
>> Here it is:
>> [19-Jan-2011 07:50:32] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 07:50:32] PHP Warning:  Module 'imagick' already loaded
>> in Unknown on line 0
>> [19-Jan-2011 07:50:32] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 09:06:40] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 09:06:40] PHP Warning:  Module 'imagick' already loaded
>> [19-Jan-2011 09:06:40] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 09:09:08] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 09:09:08] PHP Warning:  Module 'imagick' already loaded
>> [19-Jan-2011 09:09:08] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 10:08:06] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 10:08:06] PHP Warning:  Module 'imagick' already loaded
>> [19-Jan-2011 10:08:06] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 10:08:17] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 10:08:17] PHP Warning:  Module 'imagick' already loaded
>> [19-Jan-2011 10:08:17] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 16:20:34] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 16:20:34] PHP Warning:  Module 'imagick' already loaded
>> [19-Jan-2011 16:20:34] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 16:45:07] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 16:45:07] PHP Warning:  Module 'imagick' already loaded
>> [19-Jan-2011 16:45:07] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 17:54:17] PHP Warning:  Module 'gd' already loaded in
>> Unknown on line 0
>> [19-Jan-2011 17:54:17] PHP Warning:  Module 'imagick' already loaded
>> [19-Jan-2011 17:54:17] PHP Warning:  Module 'pgsql' already loaded in
>> Unknown on line 0
>>> Sounds like an untested PHP/Apache/Postgres configuration .. never
>>> heard of so much hassle with an installation.
>> I have no problems now with 2.6.2.
>> mapbender_setup.php says all ok in both versions And.. yes, CentOS is
>> a nightmare.
>> By the way, can I import the OpenLayers example of 2.7 in 2.6.2, or I
>> need another version of the app?
>> thanks
>>> Thanks,
>>> Christoph
>>>>> 2011/1/19 Christoph Baudson <christoph at baudson.de>:
>>>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>>> Hash: SHA1
>>>>>> On 01/19/2011 07:16 PM, Hernan Olivera wrote:
>>>>>>> 2011/1/19 Thoralf Kauk <tkauk at t-online.de>:
>>>>>>>> Am 19.01.2011 14:13, schrieb Hernan Olivera:
>>>>>>>>> News:
>>>>>>>>> I've installed 2.6.2 in the same machine, withouth any problem.
>>>>>>>>> Now this is my scenario:
>>>>>>>>> 1) Solve 2.7 problems to work
>>>>>>>>> 2) Use 2.6.2, but need to know what to do to use Openlayers example.
>>>>>>>>> Someone can help?
>>>>>> Hi Hernan, pleae install Firebug and check for JavaScript error messages.
>>>>> I'm just doing that. There's no errors reported by firebug in 2.7
>>>>> apps (that hangs 'loading applicattion gui, gui1, gui2...').
>>>>> But I can see that the head section ends after the title and then
>>>>> all css is in the body.
>>>>> But this is what firebug shows. If I look at the source code of
>>>>> the page as is shown by firefox, the head section closes after all css.
>>>>> Strange...
>>>>> Searching...
>>>>> Hernan Olivera
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.10 (GNU/Linux)
>>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>>> iEYEARECAAYFAk03Vo0ACgkQGtMIfbycMX7v8wCfTXSYX4qu3ChNvqgVWMPdT6Ol
>>> p3UAn16SEriExsLeEBSwFuEYCdPXQj/N
>>> =qeAb
>>> -----END PGP SIGNATURE-----
>> Hernan Olivera
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users mailing list
