[Mapbender-users] WMS geoserver-mapbender error
Hernan Olivera lholivera at gmail.com
Fri Jan 28 14:07:04 EST 2011
Hello
If this helps, I have received the same error, maybe there is
something wrong in the installation.
I fixed this making a fresh install.
greeetings
2011/1/28 Valenty Gonzalez <gvalenty at gmail.com>:
> I have been working with geoserver-2.0.2 for a
> new project in which we use as a portalMapbender.
> I have a problem, mapbender do not read the wms from geoserver
> I've also done a test with GeoWebCache where you can
> make a configuration forserving the tiles (wmst) like
> wms and I've verified that it works in gvSIG.
> but I get the same error in mapbender; mapbender can't read it.
> I send the error that report Mapbender and the GetCapabilities file.
> Mapbender error:
> file: http://192.168.0.169:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabilities&version=1.1.1sql error: ERROR: insert
> or update on table "layer_keyword" violates foreign
> key'fkey_layer_id_fkey_keyword_id "DETAIL: Key (fkey_layer_id)
> = (20,139) is notpresent in table 'layer'. Performed ROLLBACK ....
> Any idea?
> Thanks in advance
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Hernan Olivera
More information about the Mapbender_users mailing list
