[Mapbender-users] PrintPDF doesn't work
Manns, Marc Marc.Manns at remscheid.de
Mon Jun 20 03:12:46 EDT 2011
Hi Emilio,
Maybe there is a hint in your mapbender error-log file.
To activate it, you have to be sure that your webserver
owner got write access to your
mapbender/log  folder.
To activate mapbender's error logging
you have to edit your
mapbender.conf.
switch;
define("LOG_LEVEL", "off");
to:
define("LOG_LEVEL", "error");
cheers Marc
When I enable the log I get an error loading mapbender after restarting Apache. I set the following parameters in the php.ini:
*	display_errors = Off
*	log_errors = On
*	error_log = php_errors.log
On the other hand I changed memory_limit from 128M to 256M and I still don't get the pdf.
Any idea?
Emilio.
2011/6/19 Christoph Baudson <christoph at baudson.de>
	-----BEGIN PGP SIGNED MESSAGE-----
	Hash: SHA1
	On 06/19/2011 09:08 PM, Emilio de Torres Fernández wrote:
	> Hello,
	> I'm trying to print a pdf but I don't get anything. I have checked
	> mapbender.conf and I have correctly configured TMPDIR for temporary files
	> and I have given write permissions for the directory to the webserver(Apache
	> running in Windows) but no file is created there.
	> What can be wrong?
	Have you checked your php log file? It is specified under error_log in
	php.ini. Make sure log_errors is activated. Maybe you need to increase
	the memory limit in php.ini in order to print.
	Christoph
	> Best regards.
	> Emilio.
	> Mapbender_users mailing list
	> Mapbender_users at lists.osgeo.org
	> http://lists.osgeo.org/mailman/listinfo/mapbender_users
	-----BEGIN PGP SIGNATURE-----
	Version: GnuPG v1.4.10 (GNU/Linux)
	Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
	iQEcBAEBAgAGBQJN/kwLAAoJEDZfGi47DjZ7ZLYH/R3sdALoVDmYJ4sFWxZZ6ebL
	WWJA/yMDMmf7cdPuXMQJz0vkg63SvCJo+fqkoORNHcG+PbQGX+8Q23h+53Zb1fUS
	qghBrhB+srxTJbXIByYb+Tgz9EYGgcIm16pDr1diDCtaD5cyH7ka1PvcvVVUK81f
	/rT6tBEn1Pq4dRo6jAHruRKTYNsd6CKWzlUT2uUHeTbmSqRwuZ7gRZ0bc4Dg8sZ7
	u5cBg5438a9taWBO6B0N1FW2ib6T68pmoO+3xBTla1M44L+9WPm6WsqdtTWSBGij
	wKvzgMFjCbuE+QkEmczzh2w53AI0QywMmUFwmgp5w4dgtkMrmpYBYq4xRg834zk=
	=47s5
	-----END PGP SIGNATURE-----
Un saludo.
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110620/6cdf9aee/attachment.html
More information about the Mapbender_users mailing list
