AW: AW: [Mapbender-users] Problem with fresh install of 2.7.1 on debian
zorg zorg at probesys.com
Tue May 31 10:53:01 EDT 2011
Still have this problem get the same thing on a fresh debian squeeze install
no error on apache log
but here is what I have when i log gui1
Le 31/05/2011 15:49, Manns, Marc a écrit :
> the error.log seems to be Ok.
> these errors shouldn't make that trouble.
> You previously wrote: "setup seem to be ok"!
> Do you mean the setup.php?
> You could also check your apache.log
> while loading your application.
> Marc
> Hello
> here is my log
> I have different error
> hope it can help
> Le 31/05/2011 13:56, Manns, Marc a écrit :
>> Hi,
>> if you've installed Mapbender with the install script, you could check
>> the logfile under:
>> /mapbender/ressources/db/error.log
>> ...and see if you had some trouble
>> during the database Installation.
>> regards Marc
>> Hi
>> thanks for your help
>> on the page I have only this
>> 2.7.1 ...loading application 'gui1'
>> plus the images
>> but nothing open
>> no error with firebug
>> what can I do
>> Le 31/05/2011 08:56, Verena Diewald a écrit :
>>> Hi,
>>> do you use Mozilla Firefox? Then you could install the add-on Firebug
>>> for debugging. Reload your guis with an activated Firebug console and
>>> let us know if an error appears there.
>>> Best regards,
>>> Verena
>>> Am 30.05.2011 17:27, schrieb zorg:
>>>> Hi
>>>> I've a fresh install of the 2.7.1 mapbender but the gui,gui1,gui2
>>>> not working I have no error in the log gui_digitize is working and
>>>> other thing also
>>>> I have one more strange thing
>>>> admin_wms_metadata is not working also
>>>> setup seem to be ok
>>>> Does anyone have a clue or can help me to see where look
>>>> thank
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Type: text/x-log
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110531/250e3a69/mb_error_2011_05_31-0001.bin
More information about the Mapbender_users mailing list
