[Mapbender-users] Problem with fresh install of 2.7.1 on debian
zorg zorg at probesys.com
Tue May 31 11:28:56 EDT 2011
I'm using debian with apache2 php module
but even in debug mod I have not error in error.log
really don't know what I doing wrong
does anyone have install mapbender 2.7 on debian squeeze
Le 31/05/2011 16:54, Verena Diewald a écrit :
> Hi,
> could you please check your php log. Perhaps you can find some detail
> information about the problem there.
> Everything alright in this log while loading your guis?
> Greetings,
> Verena
> Am 31.05.2011 16:53, schrieb zorg:
>> Still have this problem get the same thing on a fresh debian squeeze
>> install
>> no error on apache log
>> but here is what I have when i log gui1
>> Le 31/05/2011 15:49, Manns, Marc a écrit :
>>> the error.log seems to be Ok.
>>> these errors shouldn't make that trouble.
>>> You previously wrote: "setup seem to be ok"!
>>> Do you mean the setup.php?
>>> You could also check your apache.log
>>> while loading your application.
>>> Marc
>>> Hello
>>> here is my log
>>> I have different error
>>> hope it can help
>>> Le 31/05/2011 13:56, Manns, Marc a écrit :
>>>> Hi,
>>>> if you've installed Mapbender with the install script, you could check
>>>> the logfile under:
>>>> /mapbender/ressources/db/error.log
>>>> ...and see if you had some trouble
>>>> during the database Installation.
>>>> regards Marc
>>>> Hi
>>>> thanks for your help
>>>> on the page I have only this
>>>> 2.7.1 ...loading application 'gui1'
>>>> plus the images
>>>> but nothing open
>>>> no error with firebug
>>>> what can I do
>>>> Le 31/05/2011 08:56, Verena Diewald a écrit :
>>>>> Hi,
>>>>> do you use Mozilla Firefox? Then you could install the add-on Firebug
>>>>> for debugging. Reload your guis with an activated Firebug console and
>>>>> let us know if an error appears there.
>>>>> Best regards,
>>>>> Verena
>>>>> Am 30.05.2011 17:27, schrieb zorg:
>>>>>> Hi
>>>>>> I've a fresh install of the 2.7.1 mapbender but the gui,gui1,gui2
>>>>>> not working I have no error in the log gui_digitize is working and
>>>>>> other thing also
>>>>>> I have one more strange thing
>>>>>> admin_wms_metadata is not working also
>>>>>> setup seem to be ok
>>>>>> Does anyone have a clue or can help me to see where look
>>>>>> thank
>>>>>> _______________________________________________
>>>>>> Mapbender_users mailing list
>>>>>> Mapbender_users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110531/5a235a1c/attachment.html
More information about the Mapbender_users mailing list
