[Mapbender-users] Installation problem "Compiling .po files..."
Astrid Emde astrid.emde at wheregroup.com
Wed Nov 30 07:34:22 EST 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello,
at the moment we only provide an i18n_update_mo.sh at mapbender/tools.
The script install.bat copies i18n_update_mo.sh to i18n_update_mo.bat
and runs the bat.
Try to create the file i18n_update_mo.bat by hand and run it. This
should create the Mapbender mo-files.
Best regards Astrid
dstroeer at uni-osnabrueck.de schrieb:
> Hello everybody,
> I've got a problem with the installation of mapbender. You can find the
> error message below...
> I'm using windows 7 and mapbender 2.7.2 and allready tried it with
> mapbender 2.6.2. PostgreSQL and Poedit are allready installed, too.
> So first of all a asked a friend, who also uses mapbender 2.6.2 and
> windows 7. His application is running fine, but when he tried to run the
> install.bat for windows again, he got the same message! So we are at a
> loss...
> Thanking you in anticipation,
> Dennis
> DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!
> This script will create a database for you and will import the Mapbender
> data to
>  the new database
> It will possibly also compile the Mapbender.mo files
> You need:
> - a running postgresql 8.x database
> - database user with write access
> If everything is prepared you can continue.
> You can give nearly all arguments on commandline:
> "C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat <HOST> <PORT>
> <DBNAME>
>  <DBTEMPLATE> <DBUSER>"
> e.g.
> C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat localhost 5432
> mapbende
> r template0 postgres
> Continue?
> (y)es or (n)o:y
> Database host (just hit return for default 'localhost'):
> Database port (just hit return for default '5432'):
> Database name:mapbender
> database template to use (just hit return for default 'template0'):
> Database user:postgres
> Database Password will be asked many times during install, unless
> pgpass.conf is
>  used...
> Your Choices:
> Databasetype: PostgreSQL
> Encoding: UTF-8
> Database Host: localhost
> Database Port: 5432
> Database Name: mapbender
> Database Template: template0
> Database User: postgres
> Looks ok, start install?
> (y)es or (n)o? y
> creating db
> creating schema
> importing data
> setting sequences
> performing updates
>   update to 2.5.1rc1
>   update to 2.5.1
>   update to 2.6rc1
>   update to 2.6
>   update to 2.6.1
>   update to 2.6.2
>   update to 2.7rc1
>   update to 2.7rc2 to 2.7.1
>   update to 2.7.2
>   update sequences
> Das System kann den angegebenen Pfad nicht finden.
> please check and edit your mapbender.conf.
> FINDSTR: i18n_update_mo.sh kann nicht geöffnet werden.
> Finished...check the log files to see if an error occured.
> Drücken Sie eine beliebige Taste . . .
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Where2B Konferenz 2011
01. Dezember 2011 in Bonn
http://www.where2b-conference.com
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAk7WIs4ACgkQBtpS1y1RUoQgfgCePSTuaY4exR0zaMLs96MIej23
8FoAoKBTH6z5slBLLbdkdwgXy02lbCLx
=oeij
-----END PGP SIGNATURE-----
More information about the Mapbender_users mailing list
