[Mapbender-users] Re: GeoServer WMS einbinden
Christian Röttger chris.roettger at uni-muenster.de
Thu Sep 8 06:32:10 EDT 2011
Am 06.09.2011 12:45, schrieb Albert Polze:
> Hello Christian,
> I also had a lot of trouble to get my geoserver working. I cannot confirm
> your assumption of the EPSG-Codes. With Mb 2.7-1 and GS 2.1.1 everything
> works fine. Be cause im also a beginner i don't know if any server-settings
> are incorrect (server-timeout?) but maybe your Get-Capabilities Request is
> wrong? Here is mine:
> http://xxx.xxx.xx.xx:8080/geoserver/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> Maybe you should have a look into your geoserver-error.log / request.log ?
> Greetings Albert
Hello,
if i "normally" try to upload my capabilities, this is the answer:
file:
http://server:8080/geoserver/vietnam/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
When i add my EPSG code to a limited SRS list in geoserver wms, the
upload works.
I wonder if this problem is geoserver or mapbender related.
The next problem is that i can only choose 4326 for all my layers and
not the layers source system 32648.
This is a part from the capabilities upload summary in mapbender. maybe
thats the problem but i don't know how and where i can fix it:
gui_wms_epsg: EPSG:4326
wms_srs: EPSG:32648
greets
christian
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110908/d293edec/smime.bin
More information about the Mapbender_users mailing list
