[Mapbender-users] Installation problem "Compiling .po files..."
Sebastian Luhmer S.Luhmer at geoserv.de
Tue Apr 23 02:37:14 PDT 2013
Hallo Liste,
das Problem habe ich auch. Ich möchte Mapbender in einer Windows 7-Umgebung einrichten und hänge auch an dieser Stelle fest. Gibt es dazu mittlerweile eine Lösung bzw. weitere Erfahrungen. Ich habe Astrids Workaround ebenfalls durchgeführt (händisches Erstellen der i18n_update_mo.bat) und bekomme die gleiche Fehlermeldung wie Dennis.
Gruß!
Sebastian
Hi List,
i got the same problem like Denis. I try to set up a mapbender-Installation on Windows 7 and stuck at the same point. I created the i18n_update_mo.bat by hand but still get the same error message like before. Are there any further experiences regarding that problem or a solution?
Regards!
Sebastian
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von dstroeer at uni-osnabrueck.de
Gesendet: Dienstag, 6. Dezember 2011 16:13
An: Mapbender User List
Betreff: Re: [Mapbender-users] Installation problem "Compiling .po files..."
Hello,
I still have problems with the installation of mapbender.
I dropped my existing mapbender database and created the file
i18n_update_mo.bat by hand. This means that I copied the content of the
i18n_update_mo.sh - file and saved it as a i18n_update_mo.bat - file.
After that I ran that script and tried to create the mapbender database
again with the install.bat - file. But I got the same error message again!
So know I want to know if I misunderstood your solution or if I made
another mistake?
Thanking you in anticipation,
Dennis
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello,
> at the moment we only provide an i18n_update_mo.sh at mapbender/tools.
> The script install.bat copies i18n_update_mo.sh to i18n_update_mo.bat
> and runs the bat.
> Try to create the file i18n_update_mo.bat by hand and run it. This
> should create the Mapbender mo-files.
> Best regards Astrid
> dstroeer at uni-osnabrueck.de schrieb:
>> Hello everybody,
>> I've got a problem with the installation of mapbender. You can find the
>> error message below...
>> I'm using windows 7 and mapbender 2.7.2 and allready tried it with
>> mapbender 2.6.2. PostgreSQL and Poedit are allready installed, too.
>> So first of all a asked a friend, who also uses mapbender 2.6.2 and
>> windows 7. His application is running fine, but when he tried to run the
>> install.bat for windows again, he got the same message! So we are at a
>> loss...
>> Dennis
>> DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!
>> This script will create a database for you and will import the Mapbender
>> data to
>>  the new database
>> It will possibly also compile the Mapbender.mo files
>> You need:
>> - a running postgresql 8.x database
>> - database user with write access
>> If everything is prepared you can continue.
>> You can give nearly all arguments on commandline:
>> "C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat <HOST> <PORT>
>> <DBNAME>
>>  <DBTEMPLATE> <DBUSER>"
>> e.g.
>> C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat localhost 5432
>> mapbende
>> r template0 postgres
>> Continue?
>> (y)es or (n)o:y
>> Database host (just hit return for default 'localhost'):
>> Database port (just hit return for default '5432'):
>> Database name:mapbender
>> database template to use (just hit return for default 'template0'):
>> Database user:postgres
>> Database Password will be asked many times during install, unless
>> pgpass.conf is
>>  used...
>> Your Choices:
>> Databasetype: PostgreSQL
>> Encoding: UTF-8
>> Database Host: localhost
>> Database Port: 5432
>> Database Name: mapbender
>> Database Template: template0
>> Database User: postgres
>> Looks ok, start install?
>> (y)es or (n)o? y
>> creating db
>> creating schema
>> importing data
>> setting sequences
>> performing updates
>>   update to 2.5.1rc1
>>   update to 2.5.1
>>   update to 2.6rc1
>>   update to 2.6
>>   update to 2.6.1
>>   update to 2.6.2
>>   update to 2.7rc1
>>   update to 2.7rc2 to 2.7.1
>>   update to 2.7.2
>>   update sequences
>> Das System kann den angegebenen Pfad nicht finden.
>> please check and edit your mapbender.conf.
>> FINDSTR: i18n_update_mo.sh kann nicht geöffnet werden.
>> Finished...check the log files to see if an error occured.
>> Drücken Sie eine beliebige Taste . . .
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> Where2B Konferenz 2011
> 01. Dezember 2011 in Bonn
> http://www.where2b-conference.com
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 19
>  Fax: +49(0)228 90 90 38 - 11
>  astrid.emde at wheregroup.com
>  www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
>  pgp-public key:
>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>   Signed and/or encrypted mail is highly appreciated
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAk7WIs4ACgkQBtpS1y1RUoQgfgCePSTuaY4exR0zaMLs96MIej23
> 8FoAoKBTH6z5slBLLbdkdwgXy02lbCLx
> =oeij
> -----END PGP SIGNATURE-----
More information about the Mapbender_users mailing list
