[Mapbender-users] Problem with wms in a mapbender copy
Armin Retterath armin.retterath at gmail.com
Tue Aug 20 09:53:33 PDT 2013
hello charles,
check your curl connection - is the server able to get urls from the given
ip s and ports?
do you work via proxy?
here is our connection configuration (mapbender.conf)
# type of server-connection
# curl, socket, http
define("CONNECTION", "curl");
#define("CONNECTION", "http");
#define("CONNECTION", "socket");
define("CONNECTION_PROXY", "XX.XX.XX.XX"); // ip
define("CONNECTION_PORT", "8080"); // port
#define("CONNECTION_PROXY", ""); // ip
#define("CONNECTION_PORT", ""); // port
#define("CONNECTION_USER", ""); // user
define("CONNECTION_PASSWORD", ""); // password
define("CONNECTION_USERAGENT", "Mapbender");
# HOSTs not for Proxy (curl)
define("NOT_PROXY_HOSTS", "localhost,127.0.0.1");
we work via proxy.
if you have no proxy you have to define empty strings like:
i think, that your server has no connection to the network - or no php-curl
module installed? (php5-curl)
please test to load the capabilities url via wget or curl at the shell. to
use a proxy you may have first set the proxy environment:
export http_proxy=http://YOURPROXYIP:YOURPROXYPORT
wget -O /tmp/test1.xml '
http://190.0.131.104:8080/geoserver/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
if the url can be loaded via curl you may have s.th. to to with the missing
library.
regards
armin
2013/8/20 Charles Nievas <cnievas-npm at adinet.com.uy>
> When i try to load wms from local geoserver mapbender tell me
> file: http://127.0.0.1:8080/**geoserver/wms?REQUEST=**
> GetCapabilities&SERVICE=WMS&**VERSION=1.1.1sql<http://127.0.0.1:8080/geoserver/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1sql>error: ERROR: no existe una sentencia preparada sin nombre ROLLBACK
> performed....
> Thanks very much
> ______________________________**_________________
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.**org <Mapbender_users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapbender_**users<http://lists.osgeo.org/mailman/listinfo/mapbender_users>
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20130820/5cd13e63/attachment.html>
More information about the Mapbender_users mailing list
