[Mapbender-users] Load WMS issue
Armin Retterath armin.retterath at lvermgeo.rlp.de
Wed Jan 23 00:39:51 PST 2013
Hi Ramesh,
first: please use Version 1.1.1 for the WMS Capabilities REQUEST,
second: you can try to load the Capabilities Document from file system.
Store the XML which is shown to in the browser window to a location
where the  apache can read it - maybe temp folder. Then give simple the
path to the local document in the loadWMS window.
E.g.:
file:///temp/capabilities1.xml
and load it localy.
If this is successful, you have a network problem.
If not - maybe the capabilities parsing makes problems.
Look in the mapbender log folder. In the current log file, there are
more messages which may help to identify the problem.
Do you use curl? Normaly this works well for localhost.
Maybe you can send me your capabilities xml and I may test it with
mapbender trunk.
Regards
Armin
On 23.01.2013 09:00, Ramesh De Silva wrote:
> Hello Armin,
> Thanks a lot for the reply.
> I am inside a university network but proxy settings are unknown to the
> users. We set "automatically detect Proxy" in browser settings. May be
> I can request proxy information from university network administration
> and try to provide values in the mapbender.conf.
> But my worry is; with the WMS running in localhost also I get this
> issue. I have set NOT_PROXY_HOSTS as follows
> *define("NOT_PROXY_HOSTS", "localhost");*
> By the way I am running everything on Windows 2003 Server.
> The imagick extension is not enabled in php.ini yet. Does it have any
> impact for this? Actually I disabled it as I couldn't start Apache
> after enabling this extension.
> Thank you.
> Best Regards
> Ramesh
> On Wed, Jan 23, 2013 at 2:01 PM, Armin Retterath
> <armin.retterath at lvermgeo.rlp.de
> <mailto:armin.retterath at lvermgeo.rlp.de>> wrote:
>     Hello Ramesh,
>     it seems to be a http connection problem. Do you work behind a
>     proxy? You have to define the proxy variables in the
>     conf/mapbender.conf file.
>     I recommend to use the connection via curl library. It is very
>     good in most environments.
>     Do you use mapbender under windows or linux?
>     If you don't have a proxy test the following configuration:
>     define("CONNECTION", "curl");
>     #define("CONNECTION", "http");
>     #define("CONNECTION", "socket");
>     #define("CONNECTION_PROXY", "xxxx"); // ip
>     #define("CONNECTION_PORT", "xxxx"); // port
>     define("CONNECTION_PROXY", ""); // ip
>     define("CONNECTION_PORT", ""); // port
>     define("CONNECTION_USER", ""); // user
>     define("CONNECTION_PASSWORD", ""); // password
>     define("CONNECTION_USERAGENT", "Mapbender");
>     (libcurl and php5-curl is needed)
>     Regards
>     Armin
>     On 23.01.2013 07:38, Ramesh De Silva wrote:
>>     Hello,
>>     I have a problem in loading any WMS to Mapbender. When I try to
>>     load a WMS using a WMS Capabilities URL; nothing happens. It
>>     shows me the WMS Capabilities URL itself in the resulting screen.
>>     The WMS Capabilities URLs I used as follows
>>     *From Localhost:*
>>     http://localhost:8080/geoserver/GIC/wms?service=WMS&version=1.1.0&request=GetCapabilities
>>     *Then from other WMS sources
>>     *Cadastre of spain*
>>     http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
>>     *Bird Studies Canada*
>>     http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
>>     <http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS>
>>     I am running Geoserver version 2.2.1 and Mapbender 2.7.3 in my
>>     machine. The default maps provided in Mapbender are working fine.
>>     Really appreciate any help to resolve this problem.
>>     Thank you.
>>     Best regards
>>     Ramesh
>>     _______________________________________________
>>     Mapbender_users mailing list
>>     Mapbender_users at lists.osgeo.org  <mailto:Mapbender_users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapbender_users
>     Zentrale Stelle Geodateninfrastruktur
>     Rheinland-Pfalz
>     LVermGeo-RP
>     Ferdinand-Sauerbruch-Straße 15
>     56073 Koblenz
>     0261/492-466
>     armin.retterath at lvermgeo.rlp.de  <mailto:armin.retterath at lvermgeo.rlp.de>
>     http://www.geoportal.rlp.de
Rheinland-Pfalz
LVermGeo-RP
56073 Koblenz
0261/492-466
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20130123/642fe350/attachment.html>
More information about the Mapbender_users mailing list
