[Mapbender-users] Search Router
Astrid Emde astrid.emde at wheregroup.com
Thu Aug 14 05:17:21 PDT 2014
Hello Stephan,
you should prefer lower case for your table and column names ;)
You can try to escape your columnames and tablenames if they use uppercase.
Doctrine will understand the " as part of the name. Give it a try and
please give feeadback how it works
attributes:
  - '"Bezeichnung'"
  - '"Variante'"
Best regards Astrid
If this does not work you could use a view with lower case instead.
Best regards
Astrid
Am 2014-08-12 16:06, schrieb Stephan Klemm:
> Sorry, i mean the search router widget...
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html
> [1]
> Best regards
> GESENDET: Dienstag, 12. August 2014 um 14:19 Uhr
>  VON: Stephan.Klemm at gmx.org
>  AN: mapbender_users at lists.osgeo.org
>  BETREFF: Fw: Simple search Mapbender3
> Hello,
> is it possible to use capital letters for attribute-names in the
> simplesearch and are there examples?
> My previous attempts failed with capital letters.
> For example:
> class: Mapbender\CoreBundle\Component\SQLSearchEngine
>  class_options:
>  connection: search_db
>  relation: relation.relation
>  attributes:
>  - Bezeichnung
>  - Variante
> Thanks und regards
> Stephan
> GESENDET: Dienstag, 12. August 2014 um 11:09 Uhr
>  VON: "Astrid Emde" <astrid.emde at wheregroup.com>
>  AN: "Mapbender User List" <mapbender_users at lists.osgeo.org>
>  BETREFF: Re: [Mapbender-users] Simple search Mapbender3
> Hello,
>  at the moment we use simplesearch only with SOLR.
>  Have a look at
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/simplesearch.html
> [2]
>  Best regards
>  Astrid Emde
>  GIS-Consultant
>  Am 2014-08-11 16:15, schrieb mato:
>  > Hello,
>  > is there any example how to set up the simple search widget for
>  > searching
>  > using WFS service (geoserver, QGIS)?
>  > I am using mapbender3.
>  > Thank you.
>  > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Simple-search-Mapbender3-tp5155816.html
> [3]
>  > Sent from the mapbender-users mailing list archive at Nabble.com.
>  > _______________________________________________
>  > Mapbender_users mailing list
>  > Mapbender_users at lists.osgeo.org
>  > http://lists.osgeo.org/mailman/listinfo/mapbender_users [4]
>  Mit freundlichen Grüßen
>  Astrid Emde
>  GIS-Consultant
>  Aufwind durch Wissen!
>  Qualifizierte OpenSource-Schulungen
>  bei der www.foss-academy.eu [5]
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 19
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com [6]
>  Folgen Sie der WhereGroup auf twitter:
>  http://twitter.com/WhereGroup_com [7]
>  Amtsgericht Bonn, HRA 6788
>  Komplementärin:
>  WhereGroup Verwaltungs GmbH
>  vertreten durch:
>  Olaf Knopp, Peter Stamm
>  pgp-public key:
>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [8]
>  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>  Signed and/or encrypted mail is highly appreciated
> Links:
> [1]
> [2]
> [3]
> [4] http://lists.osgeo.org/mailman/listinfo/mapbender_users
> [5] http://www.foss-academy.eu
> [6] http://www.wheregroup.com
> [7] http://twitter.com/WhereGroup_com
> [8] http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Astrid Emde
GIS-Consultant
 Astrid Emde
 Eifelstraße 7
 53119 Bonn
 Germany
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Komplementärin:
vertreten durch:
 pgp-public key:
More information about the Mapbender_users mailing list
