[Mapbender-users] app_dev.php is not opening
Astrid Emde astrid.emde at wheregroup.com
Thu Apr 23 04:41:12 PDT 2015
Hello Naresh,
I think you tried to open the following link with mapbender3. You have
firebug for your browser? You could check whether you get an error
message there.
http://localhost/mapbender3/app_dev.php
Please have a look in you apache log-file too.
These are the first advises I can give.
Best regards Astrid
Am 23.04.2015 11:18, schrieb naresh:
> Dear ALL,
>    I have installed Mapbender3.0.4.1 on windows xp machine. I have
> followed the steps given in
> http://doc.mapbender3.org/en/book/installation.html#installation-example-for-windows.
> When i am visiting the link http://localhost/mapbender/app_dev.php ->
> the page is not showing it is  keep on loading. How to run/open the
> application.
> The following info may be helpful to understand the issue
>  1. http://localhost/mapbender3/config.php showing the following message.
>  Your configuration looks good to run Symfony.
>   * Configure your Symfony Application online
>     <http://localhost/mapbender3/app_dev.php/_configurator/>
>   * Bypass configuration and go to the Welcome page
>     <http://localhost/mapbender3/app_dev.php/>
> Even if we click on above hyper links the page was not loading.
> 2. while executing the command php.exe app/console init:acl it is
> shown the message Aborting: The table with name 'postgres:acl_classes'
> already exists
> 3. Attached  parameter.yml and config.yml file. ( where i have changed
> the paramers).
> Please give suggestion/advise how to fix the issue and explore further
> map bender option
> Thanks&Regards,
> Naresh
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20150423/3eda6cef/attachment.html>
More information about the Mapbender_users mailing list
