[Mapbender-users] Help with Apache configuration
Franklin Januario da Silva Franklin.Silva at cerradinho.com.br
Mon Aug 10 09:28:51 PDT 2015
Hello,
I do not have much experience with server configuration, I am testing the application locally. Mapbender3 unzipped the files in the following directory:
C: \ OSGeo4W \ var \ www \ mapbender3
And I set up Apache as follows:
ALIAS / mapbender3 / OSGeo4W / var / www / mapbender3 / web /
<Directory / OSGeo4W / var / www / mapbender3 / web />
  Options MultiViews
  DirectoryIndex app.php
  Order allow, deny
  Allow from all
</ Directory>
I ran all the commands listed in the installation tutorial as follows:
cd \
cd C: \ OSGeo4W \ var \ www \ mapbender3
php.exe app / console doctrine: database: create
php.exe app / console doctrine: schema: create
php.exe app / console init: acl
php.exe app / console assets: install web
php.exe app / console fom: user: resetroot
php.exe app / console doctrine: fixtures:. --fixtures load = / Mapbender / src / Mapbender / CoreBundle / DataFixtures / ORM / EPSG / --append
php.exe app / console doctrine: fixtures:. --fixtures load = / Mapbender / src / Mapbender / CoreBundle / DataFixtures / ORM / Application / --append
The page loads incompletely and apache log indicates that the files are not found:
[Mon Aug 10 13:16:56 2015] [error] [client 127.0.0.1] File does not exist: C: / OSGeo4W / var / www / mapbender3 / web / application, referer: http: // localhost / mapbender3 /
[Mon Aug 10 13:16:56 2015] [error] [client 127.0.0.1] File does not exist: C: / OSGeo4W / var / www / mapbender3 / web / js, referer: http: // localhost / mapbender3 /
[Mon Aug 10 13:16:57 2015] [error] [client 127.0.0.1] File does not exist: C: /OSGeo4W/var/www/mapbender3/web/uploads/mapbender_mobile_yml/mapbender_mobile.png, referer: http: // localhost / mapbender3 /
[Mon Aug 10 13:16:57 2015] [error] [client 127.0.0.1] File does not exist: C: /OSGeo4W/var/www/mapbender3/web/uploads/mapbender_user_basic_yml/mapbender_user_basic.png, referer: http: // localhost / mapbender3 /
[Mon Aug 10 13:16:57 2015] [error] [client 127.0.0.1] File does not exist: C: /OSGeo4W/var/www/mapbender3/web/uploads/mapbender_user_yml/mapbender_user.png, referer: http: // localhost / mapbender3 /
What needs to change?
Thanks in advance.
[http://www.cerradinho.com/CBio.png]
           Agricola
          64 3634-2806
          64 9979-0608
          cerradinho.com.br<http://www.cerradinho.com.br>
More information about the Mapbender_users mailing list
